![]() | Home > Technical (L322) > Suspension Problems Please help |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
it could be the battery on its way out..how old is yours , cos in this cold weather the RR needs a good battery to keep all its ecu's going.... ... - .- -.
xixal Member Since: 22 Aug 2010 Location: York Posts: 9 ![]() ![]() ![]() |
Hi Scarey, just changed the battery 2 months ago, so I'm pretty confident its not that. I have cleared all the codes 3 or 4 times and now it seems to be ok.
when you changed the battery did you check the alternator output..if that was ok then hopefully a more knowledgeable member might help.. ... - .- -.
I scarey never checked the battry output, don't suppose you know what voltage it should be? xixal |
should be 14 to 14.5 volts on idle..... ... - .- -.
