![]() | Home > Technical (L322) > L332 twin turbo - ever been tried? |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
i think overfinch bored them out to 5ltrs and raised the compression ratios.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3668 ![]() ![]() |
Which ever way you increase your engines output, it will involve dumping more fuel in to the engine so your MPG will suffer. Having spent a few minutes looking for a turbo conversion for the BMW M62 and only coming across one setup in a 3 series track car, I think that the popular option is a Supercharger, there is a kit that uses an Eaton supercharger and it all sits under the engine cover.
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
Iirc the 4.6 x5 used the alpina engine .
And if you found an m5 lump for say $5k on eBay .
If what i see on Wikipedia is correct, they only built 59 Arnage Green Labels (BMW 4.4), so finding a second hand lump for one is going to be near on impossible. There are probably only a handful in the UK. |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2626 ![]() ![]() |
All Arnages were BMW-engined "green labels" until the old 6.75 ("Red Label") became an option in 2000, after that the 4.4 was officially known as a Green Label. Those 59 cars are the only ones sold with the BMW engine after this. |
Ok, that makes sense. How many cars did they build from 1998-2000? It can't have been many? Probably not much more than a few hundred world wide? |
Over a thousand (apparently). |
Eric Cartman Member Since: 05 Nov 2014 Location: Dublin Posts: 108 ![]() ![]() ![]() |
Id rather an S62 conversion from a BMW e39 M5, would be a serious L322 to behold. also the conversion cost wouldn't be huge as those cars are still falling in price.
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
http://bmwv8capri.yolasite.com/tuning-the-m60-m62.php
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 ![]() ![]() ![]() |
Thanks for the advice and clarifications chaps, looks like it wouldnt quite be as simple as I'd hoped!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8785 ![]() ![]() ![]() |
http://www.bobpetersenengineering.co.uk
was it RR engined or was it Rover engined. (Rover took over manufacture and development of the Meteor engine, in exchange for the gas turbine business.)
