Home > Technical (L322) > L332 twin turbo - ever been tried?
Page 2 of 3 <123>
Rangeyman
I was just wondering what could be done to tune the standard 4.4 engine rather than fit the 'quick fix' turbo.Such improvements with cylinder head,valves,porting ,exhaust,lightended pistons,improved conrods and balanced crank depending on your budget could surely give big gains in horsepower which is naturally aspired.Bearing in mind most 1 litre sports motorcycles give out 170hp+ as standard which equates to 780hp from the 4.4.I know this figure is totally unrealistic but someone out there should be able to find 500hp naturally aspired .
Post #362963 19th Dec 2015 6:53pm
Zirconblue
i think overfinch bored them out to 5ltrs and raised the compression ratios.
I suppose it depends how highly stressed you go. It's fairly easy to make an engine more powerful, but making it reliable and smooth are the difficult bit. And in the Range Rover there is the question of how long the drive train would last.
BMW did a 4.6 version of the same engine according to wikipedia.
Post #362964 19th Dec 2015 7:02pm
miggit
Which ever way you increase your engines output, it will involve dumping more fuel in to the engine so your MPG will suffer. Having spent a few minutes looking for a turbo conversion for the BMW M62 and only coming across one setup in a 3 series track car, I think that the popular option is a Supercharger, there is a kit that uses an Eaton supercharger and it all sits under the engine cover.
While there is obviously a Turbo version out there, I think that it may well be limited to the Bentley, which will put you in to Bentley prices, and they make a Range Rover look really cheap Shocked Example 1 x 19" alloy wheel for a Bentley turbo retailed at £1500.00, 15 years ago Shocked You could almost get a full set from Land Rover for that.
So if you have a desire for way more power, then I'd suggest that you look for a supercharger kit. I did see secondhand ones for £1500 Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #362978 20th Dec 2015 12:24am
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Iirc the 4.6 x5 used the alpina engine .
Good for around 350bhp .
When I was looking to buy my sc I came across a 4.4 in San Diego that had an m5 transplant . 5.0 and good for 400 Smile
Post #362983 20th Dec 2015 1:20am
Ian c2
And if you found an m5 lump for say $5k on eBay .
You could double it and get 550 Smile
http://esstuning.com/e39-m5-vt1-560-supercharger-system/
Post #362986 20th Dec 2015 1:33am
Zirconblue
If what i see on Wikipedia is correct, they only built 59 Arnage Green Labels (BMW 4.4), so finding a second hand lump for one is going to be near on impossible. There are probably only a handful in the UK.
Post #363007 20th Dec 2015 6:58am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
All Arnages were BMW-engined "green labels" until the old 6.75 ("Red Label") became an option in 2000, after that the 4.4 was officially known as a Green Label. Those 59 cars are the only ones sold with the BMW engine after this.
Post #363104 20th Dec 2015 5:42pm
Zirconblue
Ok, that makes sense. How many cars did they build from 1998-2000? It can't have been many? Probably not much more than a few hundred world wide?
Post #363109 20th Dec 2015 6:20pm
Philip
Over a thousand (apparently).
Post #363119 20th Dec 2015 7:17pm
Eric Cartman
Ireland 2010 Range Rover Autobiography TDV8 Santorini Black
Id rather an S62 conversion from a BMW e39 M5, would be a serious L322 to behold. also the conversion cost wouldn't be huge as those cars are still falling in price.
failing that the 4.6is M62 that went in the X5 is a nice power boost.
Post #363132 20th Dec 2015 9:36pm
Rangeyman
http://bmwv8capri.yolasite.com/tuning-the-m60-m62.php
An interesting read !!
Post #363367 21st Dec 2015 9:42pm
mat777
United Kingdom 2005 Range Rover Vogue 4.4 V8 Giverny Green
Thanks for the advice and clarifications chaps, looks like it wouldnt quite be as simple as I'd hoped!
The bigger 4.6 or 4.8 blocks had been at the back of my mind, but I wouldn't want or need to go down this path unless I somehow killed my current engine and required a rebuild. The S62 from the M5 is a good idea and one I've mooted to people before, however this engine apparently bears almost no resemblance to the M62 to the point where nothing would fit - the block itself is different which would cause issues with the front diff mounting, the heads have double VANOS instead of just intake valves, and there are 8 individual throttle bodies with equal length intake trumpets that means an enormous airbox with totally different plumbing Sad
mzplcg - funny you should mention that... check my signature Whistle NW060
"Red Shed" - 1982 Series 3 88" County Station Wagon
"Spirit of Great Britain" - Rolls Royce Meteor V12 engine
ZG875 - Westland Sea King (cockpit section)
"Carly Rae Jeepsen" - 2006 Jeep Commander 5.7 Hemi
"Pride Of The Road" - 1/4-scale Marshall traction engine - sold
"Georgina" - 2000 Discovery 2 TD5 ES - sold
"Windsor" - 2005 Range Rover Vogue 4.4 - dead
Post #365217 4th Jan 2016 12:00pm
http://www.bobpetersenengineering.co.uk
or have a look at these chaps as they built the RR engined bentley featured on TG. There is nothing that can't be fixed with a hammer😜😜
Post #365276 4th Jan 2016 7:37pm
Zirconblue
was it RR engined or was it Rover engined. (Rover took over manufacture and development of the Meteor engine, in exchange for the gas turbine business.)
i bet you thought the 5ltr SC was the most juicy of the Rover lumps. Laughing
Post #365320 5th Jan 2016 12:27am
miggit
Shocked Wots that got to do with getting more umph out of a ffrr? Unless your telling me there is a 27 ltr version floating around Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #365321 5th Jan 2016 12:32am
Page 2 of 3 <123>
