Home > Maintenance & Mods (L322) > Rear upper tailgate interior trim metal securing clips
anorakmark
United Kingdom 2004 Range Rover Vogue Td6 Epsom Green
Good evening to you all some assistance required if anybody can help.
I am trying to locate the metal spring clips that hold on the plastic piece of trim on the upper tailgate interior. It's the long piece of trim that covers the rear wiper motor on the interior. mine is very loose and annoying when going over bumps. Upon removal I noticed quite a few of the metal spring clips missing which attach the trim to the rear upper tailgate.
If anybody can assist do they know a LR part number for these or maybe a link to someone who supplies these. I have seen a few on ebay but the seem to be universal applications and I'm not sure if they will fit. I'm guessing it may actually be a LR stealer part. any assistance would be great
Post #362808 18th Dec 2015 7:42pm
EYC500300
should be pence each. LRdirect have them at 16p each, dan at duckworths should be able to get close to that. Thumbs Up :thumbs:
https://www.lrdirect.com/EYC500300-Clip/?s..._https=yes There is nothing that can't be fixed with a hammer😜😜
Post #362809 18th Dec 2015 7:46pm
anorakmark
Thank you so much Northernmonkeyjones, your help is great and a part number. Thank you so much. Thumbs Up Thumbs Up
Post #362810 18th Dec 2015 7:51pm
Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #362811 18th Dec 2015 7:53pm
Zirconblue
Or your local main dealer if they're not far from you.
Post #362819 18th Dec 2015 8:07pm
anorakmark
Thank you too Zirconblue Thumbs Up Thumbs Up
Post #362833 18th Dec 2015 9:00pm
lister6520
Malta 2004 Range Rover Vogue Td6 Giverny Green
Did you actuallly manage to remove the panel without breaking the plastic tabs on the pane ?
I broke nearly all of mine trying to remove it. Is there some magic spell one has to pronounce before tugging at it?
Post #363061 20th Dec 2015 2:48pm
anorakmark
Hi Lister, Mine was removed with now problem, what concerns me is once i have the new clips how do I refit it trying to line it? I am wondering it there is a knack to this? Rolling Eyes
Post #363066 20th Dec 2015 3:10pm
lister6520
I'm guessing mine must have different clips. If they hadn't broken then aligning it to put back would be the easiest thing. I ended up filing off what remained of the plastic tabs on the trim panel and glued strong magnets to it to keep it in place instead of the clips.
There's no way the spring metal clips on the tailgate structure would ever break or come loose.
What year is your RR ? Mine is 2003 or 2004 Vogue.
Post #363070 20th Dec 2015 3:24pm
The warmer the plastic is, the better, to get it off you have to pull straight against the prongs to stop them snapping, to get it back on put the metal clips into the tailgate and line up the plastic prongs by looking under the edge, once a couple are lined up it will push on straight, just be patient with it... Thumbs Up Thumbs Up Pete
-Click here for Thread-
Post #363071 20th Dec 2015 3:25pm
anorakmark
Mine is a late 2004 Vogue I believe Oct 2004.
Thanks for the advice Haylands I will give it a try once I get the cilps. Its crazy how such an object can make so much rattling Rolling Eyes
Post #363074 20th Dec 2015 3:37pm
Zirconblue
Most of mine were loose when i pulled the trim off to do the wiper motor the other week. either not pushed home properly or attached to the trim when i took it off, they're not in there that tightly.
Post #363083 20th Dec 2015 4:35pm
anorakmark
Mine is the same all loose and rattling about, so annoying. I'm going to order up the clips and give it a go. If all fails then Gaffa tape to the rescue Rolling with laughter
Post #363100 20th Dec 2015 5:31pm
Zirconblue
it looks to me like someone had been there before and put the clips on the trim before pushing it on, so half of them weren't located to start with. It's on there pretty well now, but the clips are a bit loose in their holes until you push to trim into them.
Post #363111 20th Dec 2015 6:22pm
It's a right PItA to get on right, I took mine off one the old one to do the wiper motor leak. It had been to the bodyshop for a new upper boot lid, and when I stripped it down I found that half the nibs were missing. Managed to get it back on okayish after with some bending and twisting.
The problem is the don't all locate into the boot in the same direction! Some are straight and some angled a bit which is what makes it tricky! There is nothing that can't be fixed with a hammer😜😜
Post #363115 20th Dec 2015 6:38pm
