![]() | Home > Maintenance & Mods (L322) > Rear upper tailgate interior trim metal securing clips |
anorakmark Member Since: 18 Jan 2014 Location: Chatham Kent Posts: 121 ![]() ![]() ![]() |
Good evening to you all some assistance required if anybody can help.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
EYC500300
Thank you so much Northernmonkeyjones, your help is great and a part number. Thank you so much. |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Or your local main dealer if they're not far from you. |
Thank you too Zirconblue |
lister6520 Member Since: 17 Nov 2015 Location: Zebbug Posts: 5 ![]() ![]() ![]() |
Did you actuallly manage to remove the panel without breaking the plastic tabs on the pane ?
Hi Lister, Mine was removed with now problem, what concerns me is once i have the new clips how do I refit it trying to line it? I am wondering it there is a knack to this? |
I'm guessing mine must have different clips. If they hadn't broken then aligning it to put back would be the easiest thing. I ended up filing off what remained of the plastic tabs on the trim panel and glued strong magnets to it to keep it in place instead of the clips.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8795 ![]() ![]() ![]() |
The warmer the plastic is, the better, to get it off you have to pull straight against the prongs to stop them snapping, to get it back on put the metal clips into the tailgate and line up the plastic prongs by looking under the edge, once a couple are lined up it will push on straight, just be patient with it... |
Mine is a late 2004 Vogue I believe Oct 2004.
Most of mine were loose when i pulled the trim off to do the wiper motor the other week. either not pushed home properly or attached to the trim when i took it off, they're not in there that tightly. |
Mine is the same all loose and rattling about, so annoying. I'm going to order up the clips and give it a go. If all fails then Gaffa tape to the rescue |
it looks to me like someone had been there before and put the clips on the trim before pushing it on, so half of them weren't located to start with. It's on there pretty well now, but the clips are a bit loose in their holes until you push to trim into them. |
It's a right PItA to get on right, I took mine off one the old one to do the wiper motor leak. It had been to the bodyshop for a new upper boot lid, and when I stripped it down I found that half the nibs were missing. Managed to get it back on okayish after with some bending and twisting.
