![]() | Home > Maintenance & Mods (L322) > Tick tick ticking - driving me bonkers! |
| Beach Member Since: 11 Jul 2015 Location: Bristol Posts: 54
I have a 2010 I acquired recently, on the test drive I had a similar noise. Before I picked the car up they had put in a new O.E windscreen as they put the noise down to poorly fitted replacement screen that was not an O.E screen. Maybe worth checking |
| Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395
Had a new LR OE screen fitted about three weeks ago - noise was there before it was changed but thanks for the idea 2005 L322 Vogue Gold gone
OK, good luck tracking it down |
| wokkadriver Member Since: 10 Sep 2012 Location: Hampshire Posts: 31
Might be a long shot but on a P38 I had a few years ago I had a similar annoying rattle from the vents which I tracked down to dried leaves in the air intakes. Bit of a faff getting into them through the plenum chamber but sooooo worth it in the end! |
Update -
| Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507
Is it possible you could fold a piece of soft cloth like towelling and trap it in place on the suspect plastic by trapping it in the bonnet closure, just to eliminate one possibility that it may be rattling. Agueroooooooooo. 93-20
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277
that's the Pollen filter access hatch. It looks like only one of the catches for it is located correctly.
Thanks for that - I will stuff a towel on it tomorrow as long as I don't cause any damage to the car .... Will then try to fix it with a screwdriver as suggested.
standing on a tool box helps, dropping it to access height also helps.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
And Star Wars is great too.... |
| Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217
When you say lower plastic trim , do you mean the cowl ?
Thanks for the tips guys. Looking forward to taping things up tomorrow morning to try it out. The car has had this annoying tapping sound since I had it 25k miles ago and it's the make or break weather I keep it or not and I really like the car so hope I can fix it. Shame the stealers didn't! 2005 L322 Vogue Gold gone
Just a thought ...
Just had a thought ...
| All times are GMT |
