![]() | Home > Maintenance & Mods (L322) > Disable AFS with IIDTool? |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 ![]() ![]() ![]() |
How you done the wiring? For 2010- headlights? Current vehicles
Well so long as you have added a resistor it should work, but you need to disable the AFS ASAP, as your using a CJB feed from fuses which normally go to AFS part of the headlight. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6819 ![]() ![]() ![]() |
CJB? Got - 2017 SDV8 Autobiography in Loire Blue
Central Junction Box of the car Current vehicles
Oh right |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1846 ![]() ![]() |
Fuse box |
Logged onto Gap website and downloaded the version Rob is running. Since I've had my PC reimaged since I last did an update, I also got the updater program to update the tool. All went well and the update was done on the tool and I plugged it into the car, "scanning ECU" message came up and then "IIDTool ready" message came up on the dash. At this point I attempted to connect from my iPad, but it kept saying "scanning for tools" but eventually says "IIDTool not found". I also can't see it on my PC using the controller app but the updater program picks it up straight away...........
Make sure you sync the Iid when plugged into the computer before going to the car with the ipad |
Sync the IID?
All donations to the forum for the diagrams👍
Tried that, didn't work |
Well my wiring once AFS disabled on my 2006- motor work perfectly |
