| could be, could also be a blocked sunroof drain or suchlike. The rubbers round the screen aren't the seal and are simply trim strips. The screens are bonded in, with mastic type glue, so unless it was fitted wrong in the first instance then it is unlikely to have sprung a leak!
 have a look and see if it is the original screen, (will say Landrover on it in the bottom passenger side corner) or whether it has been replaced at some point. If its original it is less likely that it is leaking through the screen as these don't often get installed wrong in the factory, if its an aftermarket screen then they can be difficult to fit and it really is a 2 man job, so may have been badly fitted at some point in the past.
 If you are convinced that its the screen leaking then it may be an idea to drive right behind someone on a newly gritted road....
  There is nothing that can't be fixed with a hammer😜😜 FFRR 4.4 SDV8 Autobiography Santorini Black.
