Home > Maintenance & Mods (L322) > How to disable EAS? - 2007MY TDV8
torekjernmoen
Norway 2007 Range Rover Vogue TDV8 Zermatt Silver
The EAS has occasionally problems with suspension height front right and drops the car on its bump stops. No leaks detected. Sensor input are fluctuating or showing out of range. 4x4 display shows wheel fully dropped or jumping up and down even when car is stationary on a flat surface...
Sensor has been replaced but no real difference. Replacement connector and a new ECU arrived today.
I would like to move the vehicle to a warm garage at work. It is minus 15 deg. Celsius outside and too cold for doing any repairs and too cold to get stranded on the road side.
- To avoid EAS dropping the car on its pump stops I would like to disable the EAS. What is the best method? Fuses, relays or iiDtool?
- Anyone experienced similar problems?
Post #365953 7th Jan 2016 10:33pm
If you have an IId tool it's easy, not sure where it is in your menu but it will be there.... Pete
Post #365974 8th Jan 2016 1:50am
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
I experienced manually operating the suspension it on my p38 .
Lots of times .
Lots and lots of times .
Too many times !!!
Laughing
I used to jumper out 2 sets of pins on the Ecu plug under the drivers seat iirc .
One set to turn the compressor on , then another pair to lift different corners .
Then a jumper left in to disable the dash lights etc .
Not sure if it's the same on the newer car , but suspect there will be a similar way to do it .
Edit:
If you can look at wiring diagrams and see if the same Ecu pins do the same thing on a p38 and an l332 , I will dig out my notes and tell you which ones to jumper .
I don't want to be held responsible for telling you which to use as I don't have time to verify they're the same on a later car ....
Post #365975 8th Jan 2016 1:56am
Ian c2
I just thought ...
In the end I got sick of dealing with it so fitted arnott coil springs .
They also sold a plug to disable .
Might be worth looking on their website
Post #365976 8th Jan 2016 1:57am
Open a door ? (not the boot) and switch off the lights. .
Post #365977 8th Jan 2016 1:59am
Ian c2
That would be an interesting drive to the workshop !!
Laughing
Post #365978 8th Jan 2016 2:06am
GraemeS
Australia
There will be a 20A suspension system fuse in the main fuse panel. Remove it whilst the vehicle is up. The fuse is required to operate the FETs (electronic switches) that operate the corner and exhaust pilot valves which when removed prevents lowering.
The replacement ecu will need calibrating.
Post #366023 8th Jan 2016 11:56am
Lost for Words
Service/Test > Suspension > Build Mode Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #366087 8th Jan 2016 5:08pm
Doh! didn't read the bit about workshop at "work". Embarassed .
Post #366126 8th Jan 2016 7:06pm
torekjernmoen
Thanks! I'll try the IIDTool. If I had stumbled over the Build mode setting I would not have guessed it could be used on road. Knowing what to look for I found this: https://www.gap-diagnostic.com/faq-items/h...uspension/
Will not drive 60km with open door... Smile
Post #366160 8th Jan 2016 11:29pm
GraemeS
Australia
MY07 on uses the D3/RRS Terrain Response system with minor s/w changes for the L322. The ecu is quite different to earlier L322s. MY10 uses the revised can-bus version that's also fitted to D4s and MY10-13 RRS, again with L322 specific prgramming.
Post #366182 9th Jan 2016 7:51am
Ian c2
I don't want to go into it too much Graeme especially now he's got it sorted , and especially as I've not looked at it in detail .
But the Ecu and inputs to it are irrelevant if it still outputs a volt signal to operate the system .
Eg . A signal to turn on the compressor , or a signal to open a valve to send air to one corner .
It's the voltage signals out that you manipulate with jumpers , so it doesn't really matter what the signals in are are you are bypassing them .
A bit like unplugging the wires from a headlight and applying 12v direct to the bulb that bulb will light up no matter how the original switch to turn it on is designed , be it auto lamps , a switch on the dash , or remote control ...
Post #366220 9th Jan 2016 2:50pm
GraemeS
Australia
Yes, still 12V for the valves and 5V for the height sensors but I was drawing attention to the totally different set of connectors and pins, that's all.
Post #366246 9th Jan 2016 8:37pm
fisha
I second the suggestion to drive with the tail gate open or on the latch . The vehicle doesn't change height if any of the doors are open or on the latch. V8 or else ...
Post #366260 9th Jan 2016 10:11pm
torekjernmoen
Build Mode seems to do the trick. Thanks! EAS isn't bothered by erratic input from height sensor anymore and I have lifted the front using IIDTool controls. One thing though. I would have liked to open the cross link valves for a moment to balance out the pressure from side to side.
Post #366768 12th Jan 2016 10:00pm
