Home > eBay & Bargain Spots > Every Lidl helps?
supershuttle
Every Lidl helps?
They have some car stuff this week including a "smart" battery charger, don't know if thats any good but I do like the look of the interior window cleaner gadget. Geoff
Post #366592 11th Jan 2016 9:27pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
If it does what it says - that's damn cheap - I paid #90 odd quid for the c Teck.... Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #366598 11th Jan 2016 10:04pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
I read a post today on one of LR Facebook pages. The guy had bought five of them over a period of time. Said they were okay for trickle charging but were hopeless at recovering a battery. He didn't rate their longevity either and recommended buying the Ring version of the Ctek.
No idea if the guy is reliable but in this world, more often than not, you only get what you pay for.
Post #366602 11th Jan 2016 10:50pm
There are quite a few people on here using the Aldi or Lidl chargers... They are spot on.
If a battery is dead or damaged no charger will bring it back. Previously..
Post #366605 11th Jan 2016 11:09pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
They have 1 major negative. If you have a power cut they default to standby mode and have to be re-set manually.
That's fine if you are around but 1 day into 3 months away and you come back to a very flat battery.
C-Tek and Halfords ones default to their previous setting, post power cut.
Other than that, the Lidl/Aldi units are fine for maintenance. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #366619 12th Jan 2016 5:22am
biggles3124
England 2008 Range Rover Vogue TDV8 Tonga Green
I have used the Lidl charger on a variety of cars and motorcycles over past 18 months and its always worked well. No it wont bring a dead battery back but I have recharged one using a normal low amp trickle charger for several days and then put it on the Lidl charger and its now working well.
Very good value
Post #366629 12th Jan 2016 9:40am
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
I bought one about 3 years ago, maybe longer from Lidl and it was about £13 I think? Works a treat especially on my RR that sits for 2 weeks then does about 10 journeys of 5-10 miles at a time. Now Ive finally got round to replacing my knackered FSR I hopefully wont be using it as often... Bow down
Post #366688 12th Jan 2016 4:04pm
rangeseb
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Ultimate Speed Car Battery Charger
Intelligent microprocessor control with diagnostics programme and controlled charging process
With reverse polarity, short circuit and overload protection as well as pulse charge for flat batteries
Suitable for most 6V and 12V car or motorcycle batteries with a 1.2 – 120Ah capacity
4 variable charging rates, max. (A): 3.8
Operating voltage: 220 – 240V ~ 50/60Hz
£13.99
Post #366707 12th Jan 2016 5:06pm
I have one on the side of the ramps... Plug most cars in if on there for a few days... Proved very reliable too... A very good point about default setting though Rolling Eyes Thumbs Up
Post #366777 13th Jan 2016 12:20am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
I have a few of them, can't argue for the money. As above, they reset when the power goes off and they don't like charging completely flat batteries - both things a Ctek doesn't have a problem with. Mode button has also failed on one of the older ones.
Post #366814 13th Jan 2016 12:05pm
rangeseb
Does anyone know when these will be back in stock???
Or does anyone have one for sale???
Cheers
Post #384457 29th Apr 2016 2:21pm
I got mine in Makro, similar charger, had it years, works great, real cheap... try them...
If not, loads of similar ones on eBay... Thumbs Up Pete
-Click here for Thread-
Post #384494 29th Apr 2016 6:45pm
rangeseb
Cheers @Haylands
the only problem with ebay is fakes! i dont know who or what to trust.
i did find this one......
http://www.screwfix.com/p/ring-rsc604-4a-s...-12v/4853g
Post #384495 29th Apr 2016 7:02pm
Fakes aren't a massive problem on ebay, I've bought thousands of things over the years and never had any problem with them...
This one seems to tick all the boxes and is less than half the other one and comes from the UK...
http://www.ebay.co.uk/itm/Battery-Charger-...Swu1VW4AIl
Thumbs Up Thumbs Up Pete
Post #384533 29th Apr 2016 9:24pm
We get 20A smart chargers here half the price of Ctec and far more robust
had an Aldi one back in the UK but after a few months they just died would get another and the same would happen so gave up , The Ctec never seemed worth the money even though we used them on the Fire Appliances and now I know they aren't . 2008 MY Supercharged
Post #384564 30th Apr 2016 5:02am
