![]() | Home > Technical (L322) > 4.2SC Noise/Droning/Reverberation |
Guys,
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 609 ![]() ![]() ![]() |
no noise from mine dan but on a2005 mine has only done 65000 not broke in yet |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
not sure what rpm the sc kicks in , so would it be idle up to 2300 rpm?..have you checked the sc oil level Dan.. ... - .- -.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2281 ![]() ![]() ![]() |
Think the s/c is engaged constantly as it is driven by the crank pulley - have you been through the intake all the way to make sure there is not a sensor disconnected thinking about it are there any faults registered |
No faults registered last time I checked on the OBD. Wondering whether to send it to LR for a check on testbook to see if they can give it a full electronic workdown. Trouble is I don't rate many LR garages highly on anything over 3 years. |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
Take the panel filter out and do your test again ... |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
My alternator was whining and that was making a noise that I thought was an intake noise/issue. Mine also made the noise at idle too. Mine had done 85k when the alternator went. The supercharger will work constantly.
Ian - will try that...
Only took 3 months for me to try this! I swear, since going self employed I have so little time my personal life moves at a glacial pace!
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
On my freelander diff bearing going, the drone noise appeared under load initially in 3Rd and 4th gears only, so it's possible to be drivetrain related. However it did get progressively worse to be noticeable through all shoes and gears over time.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
I recon it's a cat breaking up inside, they separate, sit funny and reverberate... my nearside one is doing it, sometimes the noise is awful, other times mine shuts up but every one will be different...
Fisha - Low pitched booming that seems impossible to record on my phone or dashcam. Almost feel it in ones chest rather than ears. Going to start throwing money at UJ's etc I think...
Just an update...
Dan, if it's the S/C it may just need new bearings, worth a strip and look see if it does turn out to be it... Did you play tunes on your cats..?? Have you tried removing the air filter and running it... you never know... |
