Home > Technical (L322) > 4.2SC Noise/Droning/Reverberation
Page 1 of 3 123>
dan_uk_1984
Guys,
This is a really difficult one, no-one I've taken it to seems to know what it can be, half the people can't even hear the noise!
At 1900-2300RPM under load I get a noise that almost makes your ears want to pop. It sounds like a reverberation noise or intake related noise, but you can't feel it through the car at all. At that RPM under no load I get no noise, after 2300RPM the noise goes away and is soon replaced by engine noise. Road speed is irrelevant. It is specifically RPM AND load related. It "feels/sounds" as if it's from the front of the car rather that underneath me or behind me, so think I'm right to rule out the gearbox for now?
I've replaced the exhaust from the cats onwards (not inc the cats).
Replaced the engine mounts.
Replaced the main gearbox mount.
Removed and refitted the whole intake assembly.
RPM & Load = Noise
RPM No Load = No Noise
The only difference between those who scenarios is throttle/air intake, am I right?
So that is still pointing to some sort of intake noise?
What can I try next? Could there be an issue with the Supercharger? I've not heard of this problem relating to a failing SC before.
Worth noting that the car is relatively high mileage at 170,000 miles.
Dan
Post #367091 14th Jan 2016 7:18pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
no noise from mine dan but on a2005 mine has only done 65000 not broke in yet
Post #367094 14th Jan 2016 7:43pm
not sure what rpm the sc kicks in , so would it be idle up to 2300 rpm?..have you checked the sc oil level Dan.. ... - .- -.
Post #367097 14th Jan 2016 7:53pm
Sandyt
Think the s/c is engaged constantly as it is driven by the crank pulley - have you been through the intake all the way to make sure there is not a sensor disconnected thinking about it are there any faults registered
Post #367101 14th Jan 2016 8:02pm
dan_uk_1984
No faults registered last time I checked on the OBD. Wondering whether to send it to LR for a check on testbook to see if they can give it a full electronic workdown. Trouble is I don't rate many LR garages highly on anything over 3 years.
Post #367129 14th Jan 2016 10:31pm
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Take the panel filter out and do your test again ...
Post #367130 14th Jan 2016 10:33pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
My alternator was whining and that was making a noise that I thought was an intake noise/issue. Mine also made the noise at idle too. Mine had done 85k when the alternator went. The supercharger will work constantly.
You need someone with chassis ears to have s look and listen to it.
Can you post up a video of the noise?
Cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #367342 16th Jan 2016 12:32pm
dan_uk_1984
Ian - will try that...
Zarnd - oddly I can't ever record the noise. Imagine humming to yourself, it's always much louder to you than those around..
Post #367428 16th Jan 2016 7:45pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Did you do what I suggested previously and drive the RR with the pollen filter assembly removed ? This will give you more indication of the possible source of the noise. Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #367964 19th Jan 2016 3:13pm
dan_uk_1984
Only took 3 months for me to try this! I swear, since going self employed I have so little time my personal life moves at a glacial pace!
No difference with Engine cover and air filter housing removed. I can hear the SC much more and it sounds normal but this mystery noise is still the same volume/frequency etc.
Going to investigate prop joints/bearings next I think, any other suggestions?
Post #381655 10th Apr 2016 7:00pm
fisha
On my freelander diff bearing going, the drone noise appeared under load initially in 3Rd and 4th gears only, so it's possible to be drivetrain related. However it did get progressively worse to be noticeable through all shoes and gears over time.
What type of sound is it? Metallic? Low pitch, high pitch. Booming, etc etc. V8 or else ...
Post #381702 10th Apr 2016 10:15pm
I recon it's a cat breaking up inside, they separate, sit funny and reverberate... my nearside one is doing it, sometimes the noise is awful, other times mine shuts up but every one will be different...
Give it a whack with a rubber mallet and see if they rattle at all.... Then tap them with a metal hammer, they should sound the same... any difference points to the problem.... Thumbs Up Thumbs Up Pete
Post #381710 10th Apr 2016 11:51pm
dan_uk_1984
Fisha - Low pitched booming that seems impossible to record on my phone or dashcam. Almost feel it in ones chest rather than ears. Going to start throwing money at UJ's etc I think...
Haylands - good shout, although I have replaced the exhaust up to the cats, they aren't particularly easy to get to - but I think they should be investigated more thoroughly.
Post #381751 11th Apr 2016 3:52pm
dan_uk_1984
Just an update...
Currently driving round with the engine covers off - the mechanics seem to think it's the Supercharger. At 175K it's easy to make assumptions.
It's going in next week for them to cut the SC belt and then see if the noise goes away - if it does, a new SC will be fitted at enormous expense...
Post #404678 13th Sep 2016 8:18pm
Dan, if it's the S/C it may just need new bearings, worth a strip and look see if it does turn out to be it... Did you play tunes on your cats..?? Have you tried removing the air filter and running it... you never know... Thumbs Up Thumbs Up Pete
Post #404703 13th Sep 2016 10:23pm
Page 1 of 3 123>
