Home > Maintenance & Mods (L322) > Bespoke Rear Number Plate
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Being picky I got hacked off with the rear plate which was both crooked and in my view undersize. The plate maker I use was happy to put some stock in of the plate size I specified as "possibly a market for them".
Anyway here is mine fitted, proper job now. Many thanks
Paul
Post #367572 17th Jan 2016 3:31pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
that plate looks too big imo, the size i thought was 21'' x 6''
 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #367579 17th Jan 2016 4:14pm
Pvw10
Yes bigger than std so no gaps either side and little top or bottom. Many thanks
Paul
Post #367580 17th Jan 2016 4:17pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Aesthetics aside, I'd be worried about the larger size creating a dirt trap. The smaller plate allows hosed water to sluice behind and a small bit of movement and flex to dislodge any nasties. The larger size also prevents air circulation much more than the standard size.
Post #367590 17th Jan 2016 4:58pm
Pvw10
Good thinking, me also so there is circa 5mm at the top and 2mm either side so all fluids etc are fine Many thanks
Paul
Post #367591 17th Jan 2016 5:02pm
If you use the correct pads to stick the back plates down getting water around the back is no issue.
When screwed on unless a spaces is used the gap is very hard unless you direct a hose around the edges of it... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #367684 18th Jan 2016 12:20am
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
When I bought my car the n/plates were stuck by pads. A couple of months later (July time), I was caught in heavy traffic stop / start moving slowly with the sun behind me. Unknown to me the rear plate fell off I only realised it back at the house Big Cry .
Jumped in the other car and retraced my steps and found it, went to my local main dealer and got some new plates made up and fitted on with screws / top hat bushes.
The rear n/plate location has 2 punched square holes in the outer skin, the top hat bushes press into these and the screws go in them. There is about a 2-3mm gap between back of plate and the car. The front ones screw directly into the plastic bumper.
Would I ever use sticky pads again? NEVER!!!, but like with most things, its down to personal choice.
Post #367767 18th Jan 2016 2:57pm
Pvw10
Good info there from all.
Sticky pads no way Hose for me also.
Mine you can see the screw and is the correct way hence LR put holes there to accept same, I added 2mm thick nylon washers to the rear to create a nice air gap and spider refuge grrrr Very Happy Many thanks
Paul
Post #367821 18th Jan 2016 6:33pm
n1cktdv8
Is there not a legal stance on plate size, there seems to be a rule for every other aspect of displaying number plates ! Is this where I put the car details and a bit about myself ?........
Post #367908 19th Jan 2016 10:25am
I don't know about a legal size requirement for number plates but I do know the OP's number plate isn't legal insofar as it doesn't display the manufactures name and postcode and the relevant BS number.
A picky mot tester might well fail such a car because of it.
Post #367910 19th Jan 2016 10:35am
Pvw10
There is only a legal rule re minimum size and font details.
Re detail on the bottom any normal mot person wouldn't even bother with such trivia, my cars and bikes have been this way for years. Many thanks
Paul
Post #367915 19th Jan 2016 10:48am
You might consider it trivia but unfortunately the rules have changed recently and the number plate is now part of the mot. According to my well informed mot tester your plate is certainly a potential fail.
Post #367919 19th Jan 2016 11:08am
johnboyairey
i dont want to 'handbag' the issue, but......not only is ScottyRR's plate mis-spaced, 2. it has a car make and not a uk/euro flag, 3. it has not got the plate makers postcode, 4. it has no BS symbol. (british standard) -and 5. they spelt 'autobiography' without the 'H' so, the only thing that's good for it, is, - its not upside down!
we can choose to do what we want with our cars, -but we should all be aware of the consequences, and the rules.
Post #367921 19th Jan 2016 11:08am
Pvw10
It is trivia even petty, just use a sensible mot tester who does all the important things, when was the last time people had there spare wheel checked, very few no doubt.
You pays your money and takes your choice.
Autobiography without the H oops Many thanks
Paul
Post #367923 19th Jan 2016 11:18am
Spare wheel isn't and has never been a testable item under the MOT. Thumbs Up
Post #367925 19th Jan 2016 11:24am
