Home > Maintenance & Mods (L322) > Caliper painting
ruffy
Caliper painting
Afternoon all, a bit of advice please. I have an Overfinch TDV8 which has red calipers. One has just been replaced by the dealer I bought it from under warranty, however they have used a standard steel caliper so I need to paint it. Has anyone used brakecaliperspecialists.uk? They sell a complete kit to do 4 calipers for 30 (might as well do the others as well). Will I need to remove any of the brake components in order to paint the calipers in situ? Thanks.
Post #369907 1st Feb 2016 3:31pm
Tried searching ?
There's a few who have already done this.
Post #369908 1st Feb 2016 4:01pm
ruffy
Thanks Alistair, yes I've had a look at some of the other posts. I couldn't see any references to this supplier, and it wasn't clear for someone with limited mechanical ability (me!) whether removal of any parts is necessary before painting. 1982 SIII 88” diesel
2007 Discovery 3 V8 S
All gone: 2007 Overfinch TDV8
2007 Supercharged
1991 Vogue SE 3.9 V8
2000 Defender 90 Td5
Post #369909 1st Feb 2016 4:08pm
supershuttle
I did this just got the cheapest calliper paints, brake dust remover and stickers of eBay. Took the wheel off and brush painted in situ, obviously not red as that is for folk younger than me.
Result below and my dog has more mechanical ability than me Rolling with laughter
 Geoff
Post #369910 1st Feb 2016 4:22pm
ruffy
Looks good! I can get paint and brake cleaner from Halfords for about 15, might just do that😀 1982 SIII 88” diesel
2007 Supercharged
Post #369911 1st Feb 2016 4:26pm
Mikey
Hammerite Smooth. Never failed me yet Thumbs Up
Post #369914 1st Feb 2016 4:50pm
ruffy
Another good effort! Presumably Hammerite lasts a while too? What sort of brake cleaner did you use, and what type of brush? If I'm going to do this I don't want to Censored it up! 1982 SIII 88” diesel
2007 Supercharged
Post #369915 1st Feb 2016 4:55pm
this is one of the easiest jobs you can do....clean with a damp cloth, let dry and then paint with any metal/barbecue type paint and use any paintbrush...
dont get conned into buying special heat resistant caliper paint, you dont need that... ... - .- -.
Post #369917 1st Feb 2016 5:00pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
.... and the stickers of ebay saying brembo or range rover are actually very good and easy to apply. I brough the white rr wording and it is actually exactly the same as the original size etc. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #369929 1st Feb 2016 5:50pm
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Job done!! Thumbs Up Thumbs Up I know Craig!!!!! I'll sort it!!! 2014 vogue se
Post #369946 1st Feb 2016 6:42pm
Ennoch
For painting rough cast calipers I'd be inclined to use brush on Hammerite smooth but if you're running Brembo's then spray will give a much better finish. I've never really liked Hammerite spray and for calipers have always liked VHT Enamel. It's tough and long lasting if you leave it to dry for 24hrs before using the car. I've used it on quite a few cars that have seen the discs going purple with heat and the paint stands up remarkably well. Standard spray from Halfords is actually not a bad choice if you fancy an odd colour and it's just on something normal like the Range Rover which is highly unlikely to ever see the sort of temperatures required to blister the paint; even when hot the outside of the brake caliper stays pretty cool in the grand scheme of things.
Post #369958 1st Feb 2016 7:36pm
87RJD
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Hi
I sprayed mine with normal black heat proof paint, applied the Brembo stickers from ebay, then spayed clear lacquer to seal them in. SC 4.2, 2012 face lifted, 25K miles, 1 previous owner
Triumph TR6 1973
Triumph Bonneville 1970
Previous:
2002 TD6
Merc SL500
Escort RS Cosworth
RR 3.9 Vogue
4.2 E type Jag replica (challenger)
Escort RS2000 (many)
Escort RS 1600 Turbo
Post #369961 1st Feb 2016 8:01pm
ruffy
Thanks for all the responses, I now feel emboldened to give it a go! I will buy some Hammerite Smooth, brake cleaner and a brush and wait for a dry day Very Happy 1982 SIII 88” diesel
2007 Supercharged
Post #370047 2nd Feb 2016 10:58am
Rangeyman
Have never had the urge to bother with mine but having seen some of these pics I may just have a go !
Post #370353 3rd Feb 2016 7:17pm
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
again if this is any help to anyone
The correct colour is Gaurdsman Red - they shoiuld be Stove Enameled
Company who is one of the best is
Steve Shore @ SHORADE
have a feeling their web site is Shorade.co.uk
contact number 01543 462240
did our Porsche all 4 units - took the calipers apart - new seals & painted in the GauardsMan Red - top job
If I remember they were 100 a pop - worth every penny also included the decals in white and varnised overthe top
Post #370901 6th Feb 2016 4:21pm
