![]() | Home > Technical (L322) > Air con compressor |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2281 ![]() ![]() ![]() |
Evening gents anyone any idea where I can get a replacement zircon compressor for a 2007 s/c mine makes a soft whine at low revs - really really annoying - works perfectly just whines |
aircon as opposed to Zircon needless to say |
Josh Wyatt Member Since: 10 Jan 2011 Location: Oxford Posts: 77 ![]() ![]() ![]() |
I've used these people before for several condensers, always been good quality and arrived quickly, but never ordered a compressor from them.
The stealers wanted 1200 quid fitted and wait for it it was 580 plus vat for the unit ??
They do whine when they get low on gas , might not be as bad as you think but 296 GBP is good if you have too . 2008 MY Supercharged
Ah thanks for that will pop into local boys and get them to regas - the lube won't do any harm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Also ask them if they do a leak test when they regas. No point in regassing if there's a leak. Not all (usually those who advertise a cheap regas) do a leak test. John
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
A regas involves a vacuum check and hold which is itself a leak test One day your life will flash before your eyes......................................make sure yours is worth watching!
