Home > Technical (L322) > Air con compressor
Sandyt
Air con compressor
Evening gents anyone any idea where I can get a replacement zircon compressor for a 2007 s/c mine makes a soft whine at low revs - really really annoying - works perfectly just whines
Post #370157 2nd Feb 2016 10:54pm
Sandyt
aircon as opposed to Zircon needless to say Whistle
Post #370158 2nd Feb 2016 10:55pm
Josh Wyatt
United Kingdom 2014 Range Rover Vogue SE SDV8 Causeway Grey
I've used these people before for several condensers, always been good quality and arrived quickly, but never ordered a compressor from them.
http://www.autoairconparts.co.uk/car-air-c...-2012.html
£296 inc VAT for one doesn't seem bad!
Post #370166 2nd Feb 2016 11:03pm
Sandyt
The stealers wanted 1200 quid fitted and wait for it it was 580 plus vat for the unit ??
Thanks for the link will give them a call
Post #370167 2nd Feb 2016 11:05pm
They do whine when they get low on gas , might not be as bad as you think but 296 GBP is good if you have too . 2008 MY Supercharged
Post #370197 3rd Feb 2016 2:34am
Sandyt
Ah thanks for that will pop into local boys and get them to regas - the lube won't do any harm
Post #370204 3rd Feb 2016 8:24am
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
If you do end up needing a new one consider getting yours reconditioned. I got mine done last year after the clutch went and it was a lot cheaper than a replacement. I used a firm in Warwick called compressortech.
Post #370206 3rd Feb 2016 9:05am
Weegie
Also ask them if they do a leak test when they regas. No point in regassing if there's a leak. Not all (usually those who advertise a cheap regas) do a leak test. John
GAP iiD BT-Sold
Post #370210 3rd Feb 2016 9:46am
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
A regas involves a vacuum check and hold which is itself a leak test One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #370847 6th Feb 2016 12:10pm
