Home > Technical (L322) > Headlight bulbs
Jimmy C
United Kingdom 2003 Range Rover Vogue Td6 Zambezi Silver
Headlight bulbs
Changed my sidelight bulbs to led (TD6) now the headlight bulbs look very yellowish in comparison, can anyone point me in the direction of some headlight bulbs to match.
Post #370642 5th Feb 2016 9:20am
get some 6000k xenon bulbs of ebay..normally around £20 'ish...
type D2S if memory serves right.. ... - .- -.
Post #370652 5th Feb 2016 10:32am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Yes D2S is correct Stan.
got some for mine, haven't fitted them yet. Thumbs Up
Post #370654 5th Feb 2016 10:36am
thanks greg Thumbs Up ... - .- -.
Post #370655 5th Feb 2016 10:36am
Jimmy C
Thanks, just a straight swap???
Post #370662 5th Feb 2016 10:58am
yep...
this shows you how to get the headlight out,
Post #370671 5th Feb 2016 11:13am
Lost for Words
Bear in mind, it depends on what colour temperature the LEDs are. 6000k is most common for the best efficacy but not uniform. Mine are circa 5000k to more closely match my preference for better performing 4300k bulbs.
Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #370675 5th Feb 2016 11:22am
Jimmy C
thanks for the how to, my side light LED's are 6000k so will buy some to match.
im guessing the bolts wont come out as easy as on the video though Very Happy
Post #370714 5th Feb 2016 2:16pm
You don't need to remove the headlights to change the bulbs on a 2003 TD6 Thumbs Up
Post #370716 5th Feb 2016 2:29pm
Discotigger
^+1, as nicedayforit says, no need to remove the headlight to change the bulb, you can unclip the plastic covers off the back of the lights, undo the connectors to the lamps and unclip the bulb cover with the headlight in-situ.
Be careful though, as putting the new bulbs in can be a bit fiddly, especially on the passenger side as there is a bit less space to work in. And make sure the ignition is off, as the voltage that goes through the Xenon bulbs (28,000 Volts) is not to be messed with.
Post #370876 6th Feb 2016 2:09pm
Jimmy C
could anyone who has changed their bulbs to ds2's put a link to some decent ones on the bay, as thers so many i have no idea which to go for. Embarassed
thanks
Post #373706 23rd Feb 2016 2:40pm
go for a UK seller, you'll get them quicker and go for the 6000k bulb..
dont get this type , they wont fit properly,
get this type with the 4 anti rattle strips of metal,
these look ok,
http://www.ebay.co.uk/itm/D2S-ICE-WHITE-XE...SwMmBVud4r ... - .- -.
Post #373709 23rd Feb 2016 2:56pm
TimP
England 2005 Range Rover Vogue Td6 Java Black
There are so many listed on fleabay with prices as low as £10 a pair. However,having gone down that route thinking I've got a good deal, I have become fed up having to replace these "cheap" bulbs within a year or less so have now gone for OSRAM XENARC ORIGINAL
http://www.amazon.co.uk/gp/product/B003VNP...=8-1-fkmr2
which if you use Flubit you can get two for £53.74 with a 4 year guarantee.
Hope this helps
Tim
Post #373710 23rd Feb 2016 3:14pm
Jimmy C
Unnecessary quote removed
Going to try the cheapies first, if no good will try the expensive ones. Thanks all
Post #374103 25th Feb 2016 3:30pm
