![]() | Home > Technical (L322) > Headlight bulbs |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35856 ![]() ![]() |
get some 6000k xenon bulbs of ebay..normally around £20 'ish...
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Yes D2S is correct Stan.
thanks greg |
Jimmy C Member Since: 05 Feb 2015 Location: midlands Posts: 115 ![]() ![]() ![]() |
Thanks, just a straight swap??? |
yep...
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Bear in mind, it depends on what colour temperature the LEDs are. 6000k is most common for the best efficacy but not uniform. Mine are circa 5000k to more closely match my preference for better performing 4300k bulbs.
thanks for the how to, my side light LED's are 6000k so will buy some to match.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3985 ![]() ![]() ![]() |
You don't need to remove the headlights to change the bulbs on a 2003 TD6 |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
^+1, as nicedayforit says, no need to remove the headlight to change the bulb, you can unclip the plastic covers off the back of the lights, undo the connectors to the lamps and unclip the bulb cover with the headlight in-situ.
could anyone who has changed their bulbs to ds2's put a link to some decent ones on the bay, as thers so many i have no idea which to go for. |
go for a UK seller, you'll get them quicker and go for the 6000k bulb..
TimP Member Since: 07 Dec 2012 Location: Holmfirth Posts: 77 ![]() ![]() ![]() |
There are so many listed on fleabay with prices as low as £10 a pair. However,having gone down that route thinking I've got a good deal, I have become fed up having to replace these "cheap" bulbs within a year or less so have now gone for OSRAM XENARC ORIGINAL
Unnecessary quote removed
