![]() | Home > Maintenance & Mods (L322) > front diff recall |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6432 ![]() ![]() |
It has ended but you might be lucky if you give it a try....many have had success after the fact .
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
If it's OK after 12 years I think I'd leave it well alone, open up a can of worms changing it now I recon.... Pete
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
As Haylands says, the issue was if the diff was slightly misaligned to the front prop in the factory the splines would wear out as there is only adjustment at one end. The 'fix' was to add in another CV joint at the front so alignment wouldn't be a problem. If yours is still fine after 12 years it's been aligned correctly. The only problem may come if the alignment is altered in future, i.e. if the diff is moved or engine has to come out. I would only worry about it then. |
