Home > Maintenance & Mods (L322) > front diff recall
mark g
United Kingdom 2004 Range Rover Vogue Td6 Java Black
front diff recall
my front diff doesnt look to have been changed, is the recall still valid or has it ended now ? thanks, mark.
Post #371164 7th Feb 2016 10:29pm
It has ended but you might be lucky if you give it a try....many have had success after the fact .
Post #371165 7th Feb 2016 10:31pm
If it's OK after 12 years I think I'd leave it well alone, open up a can of worms changing it now I recon.... Pete
Post #371175 7th Feb 2016 11:04pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
As Haylands says, the issue was if the diff was slightly misaligned to the front prop in the factory the splines would wear out as there is only adjustment at one end. The 'fix' was to add in another CV joint at the front so alignment wouldn't be a problem. If yours is still fine after 12 years it's been aligned correctly. The only problem may come if the alignment is altered in future, i.e. if the diff is moved or engine has to come out. I would only worry about it then.
Post #371377 9th Feb 2016 9:56am
