Home > Technical (L322) > Limp mode help please !!!
Page 1 of 4 1234>
Dogfishdave
United Kingdom 2010 Range Rover Vogue SE 4.4 V8 Santorini Black
Hi all, just joined up. My latest RR is a 3.6 tdv8 and I love it, well I did till it started throwing up transmission fault limited gears available, tdc fault, suspension lowering and then going into limp mode.
If I switch and on again all is fine for 10 miles or 200 miles it makes its own mind up.
I have fitted a new battery, and checked the volts when standing and running, both read as they should.
Any ideas ?
Thanks Dave
Post #371533 9th Feb 2016 8:43pm
Sounds like an abs sensor or a height sensor, get the faults read and all will be revealed.... Pete
Post #371537 9th Feb 2016 9:08pm
Dogfishdave
Abs sensor, that could be a thought as the dealer that sold it to me had just had new discs and pads all round the day before he dropped it off to me.
Could they have damaged one while changing the discs.
Thanks Dave
Post #371540 9th Feb 2016 9:14pm
did you set the steering parameters when you fitted the new battery?....[how to in the wiki].. ... - .- -.
Post #371543 9th Feb 2016 9:32pm
Dogfishdave
Hi Stan, I am not sure as the dealer did it when I asked him to look at the faults.
I only had the car for 24 hrs before the faults first showed.
Can I set the stearing now?
Thanks Dave
Post #371546 9th Feb 2016 9:41pm
can do...leave it disconnected for a few hours then reconnect and turn the steering wheel fully left and then fully right.. ... - .- -.
Post #371549 9th Feb 2016 9:46pm
Dogfishdave
Stan, will I need to enter a radio code or any thing like that or just disconnect both sides and reconnect a few hrs later.
Thanks Dave
Post #371551 9th Feb 2016 9:51pm
no code needed... ... - .- -.
Post #371554 9th Feb 2016 9:54pm
Make sure you follow the correct battery disconnect procedure, not doing so can be expensive and dangerous...
Info in the wiki, link in Stans post... Pete
Post #371556 9th Feb 2016 9:57pm
Dogfishdave
Thank you both I will try it tomorrow. Thing is because the fault is very intermittent you can't tell if it's fixed.
It dropped into limp mode once when my wife was on the motorway, scared the sh#t out of her.
Thanks Dave
Post #371565 9th Feb 2016 10:41pm
Where in Brizzle are you Dave?
Post #371583 10th Feb 2016 12:17am
Oh yeah, didn't notice you were down that way, pop in and see Craig, he's a top bloke who can sort it for you.... Thumbs Up Thumbs Up Pete
Post #371588 10th Feb 2016 12:55am
Dogfishdave
Hi Craig. Live in nailsea but work bs2.
Thanks Dave
Post #371607 10th Feb 2016 8:16am
Dogfishdave
Quick update, took the car to a local Indy today, he rang me and said the code was pointing to low fuel pressure. He said take it away and use it for a while, he would give me a ring when he has time to look into it more.
I did another alternator test tonight 11.5 volts before starting then 14.5volts running with the lights on.
Is 11.5 volts !!!! The battery was only fitted two weeks back by the dealer I bought it from. It's a make I have not heard of before and only 100amps
Could this be my problem, the way I look at it low fuel pressure would be there all the time not come and go as my faults do.
Any ideas
Thanks Dave
Post #371890 11th Feb 2016 11:13pm
rar110
11.5v is discharged and will affect a L322 tdv8.
Put it on a smart charger for at least 8 hours. ______________________________
Post #371892 11th Feb 2016 11:23pm
Page 1 of 4 1234>
