Home > Maintenance & Mods (L322) > LED fogs mounting..
AzizRR
Bahrain
LED fogs mounting..
Hello there, If i may ask .. Im looking to install Morimotos LED fogs or osram ones ..
But iam afraid that the mounting are different so i am not able to do it without any modification
can anyone help/suggest a way to do it ? is there any mounting brackets that i could use?
plus am i going to face any flickering or wiring problem?
my car is pre facelift 2009
Post #372119 13th Feb 2016 2:47am
pietertje
Netherlands 2002 Range Rover Vogue 4.4 V8 Java Black
Hi, have a look here: http://www.fullfatrr.com/forum/topic33047.html?highlight=drl+fog
I think it will help you further... 2002 L322 V8
Post #372129 13th Feb 2016 10:17am
AzizRR
Bahrain
Thank you for you reply, i have read this post before, but morimoto led fogs might be a lot easier job as it only has the led fog without the DRL wiring, plus all i need to know is a way to mount the fogs because they use different brackets.
I have been told this fog light can fit perfect because it is using same bracket as my oem fogs,
https://www.theretrofitsource.com/complete...r76g_krLIU
but I might need to buy a canbus just like this one
https://www.theretrofitsource.com/morimoto...r76__krLIU
Any ideas?
Post #372132 13th Feb 2016 10:45am
pietertje
I'm not sure about the fit, since I have a MY02 car. But, by the looks of them, they might fit without to much of a hassle, though someone else can probably better comment that. I had to made a custom fit for mine, as you probably red in the thread I mentioned earlier, but it works like a charm.
I do think you need the Canbus cable (if you don't have an IDD tool to turn off the hot & cold bulb monitoring) to avoid error messages. 2002 L322 V8
Post #372141 13th Feb 2016 11:53am
AzizRR
Bahrain
can you explain the IDD tool and the hot/cold bulb thing.. i hear people talking about it but i have no idea what is it.. ' newbie '
Post #372198 13th Feb 2016 8:04pm
pietertje
The Iid tool is a tool to connect to the obd port of your car, either via bluetooth or by cable. It can read and clear all sorts of errors/messages that pop up, you can use it to read the EAS (air suspensoir) and calibrate it. Also you can config lots and lots of settings, best explained here: http://www.fullfatrr.com/forum/topic12418.html?highlight=iid+tool.
Hot and cold monitoring is the system that checks if you have any faulty light bulbs. You can disable it, per bulb, with the iid. You can also work around it by installing an additional relais, like i did. Or you could use the "canbus Cable" you mentioned earlier. 2002 L322 V8
Post #372212 13th Feb 2016 9:14pm
AzizRR
Bahrain
Thank you very much!
hope someone help me with the fogs mounting or bracket help..
Post #372213 13th Feb 2016 9:16pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Those LED fogs from retrofit source are a plug and play into the stock bracket? How bright are they compared to other LED fog options?
Am I reading this correctly that they will cause bulb errors unless you code them out with the IID tool? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #372629 16th Feb 2016 2:46pm
AzizRR
Bahrain
They're brighter than stock fogs thats for sure but what matters is the look , those gives the OEM look just like most recent models cars and even better.
Post #372630 16th Feb 2016 2:49pm
horse86
So they are a plug and play into the stock bracket?
2008 FFRR (sold)
2008 BMW M5
Post #372631 16th Feb 2016 2:53pm
AzizRR
Bahrain
Their support told me that this fog should fit l322 pre facelift as the brackets are the same even the bulb.
https://www.theretrofitsource.com/complete...sM13_krLIU
Can anyone confirm this ?
Post #372645 16th Feb 2016 4:37pm
if you look at my thread re my 'conversion' you will be able to decide if these will fit the 2006-2009 model years...
http://www.fullfatrr.com/forum/topic33047.html?highlight=drl+fog ... - .- -.
Post #372646 16th Feb 2016 4:39pm
horse86
Aziz...2010 pre-facelift or 2006 pre-facelift?
Stan...I can't see all the pics at work but weren't the LED fogs in your thread a slightly different model than these Acura ones? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #372652 16th Feb 2016 5:31pm
AzizRR
Bahrain
The 2010 pre-facelift..
Stan, i am sure your thread would help bas trust me i am newbie when it comes to fitting mods
Post #372654 16th Feb 2016 5:43pm
if yours is a 2006-2009 then those lights will not fit unless you fettle them...the standard fogs have 3 mounting tabs and those in your link have 4....
please update your car profile so we know what you have.. ... - .- -.
Post #372657 16th Feb 2016 6:39pm
