![]() | Home > Maintenance & Mods (L322) > LED fogs mounting.. |
AzizRR Member Since: 08 Feb 2016 Location: Muharraq Posts: 54 ![]() ![]() |
Hello there, If i may ask .. Im looking to install Morimotos LED fogs or osram ones ..
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 ![]() ![]() ![]() |
Hi, have a look here: http://www.fullfatrr.com/forum/topic33047.html?highlight=drl+fog
Thank you for you reply, i have read this post before, but morimoto led fogs might be a lot easier job as it only has the led fog without the DRL wiring, plus all i need to know is a way to mount the fogs because they use different brackets.
I'm not sure about the fit, since I have a MY02 car. But, by the looks of them, they might fit without to much of a hassle, though someone else can probably better comment that. I had to made a custom fit for mine, as you probably red in the thread I mentioned earlier, but it works like a charm.
can you explain the IDD tool and the hot/cold bulb thing.. i hear people talking about it but i have no idea what is it.. ' newbie ' |
The Iid tool is a tool to connect to the obd port of your car, either via bluetooth or by cable. It can read and clear all sorts of errors/messages that pop up, you can use it to read the EAS (air suspensoir) and calibrate it. Also you can config lots and lots of settings, best explained here: http://www.fullfatrr.com/forum/topic12418.html?highlight=iid+tool.
Thank you very much!
They're brighter than stock fogs thats for sure but what matters is the look , those gives the OEM look just like most recent models cars and even better. |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
So they are a plug and play into the stock bracket?
Their support told me that this fog should fit l322 pre facelift as the brackets are the same even the bulb.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35832 ![]() ![]() |
if you look at my thread re my 'conversion' you will be able to decide if these will fit the 2006-2009 model years...
Aziz...2010 pre-facelift or 2006 pre-facelift?
The 2010 pre-facelift..
if yours is a 2006-2009 then those lights will not fit unless you fettle them...the standard fogs have 3 mounting tabs and those in your link have 4....
