![]() | Home > Maintenance & Mods (L322) > auxiliary heater |
razzer Member Since: 20 Feb 2015 Location: blackpool Posts: 54 ![]() ![]() ![]() |
hi guys, my auxiliary heater (night heater)does'nt seem to get hot. it blows out cold air only. does anyone know where it is located and how much of a job is it to remove it. also what the fault is likely to be. thanks |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Loads of info on here, I would search on here but also read the two threads below on the Rover 75 forum
dazk2001 Member Since: 17 Jul 2023 Location: maidstone Posts: 24 ![]() ![]() ![]() |
dolphinboy how do you access the webasto can it be removed via the wheel arch or is it battery out thanks 2008 Range Rover 3.6 TDV8 Vogue SE |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3239 ![]() ![]() ![]() |
via wheel arch. remove the liner |
