Home > Maintenance & Mods (L322) > auxiliary heater
razzer
England 2003 Range Rover HSE Td6 Zambezi Silver
auxiliary heater
hi guys, my auxiliary heater (night heater)does'nt seem to get hot. it blows out cold air only. does anyone know where it is located and how much of a job is it to remove it. also what the fault is likely to be. thanks
Post #372611 16th Feb 2016 12:09pm
Dolphinboy
If you do a search on here for FBH (fuel Burning heater) you will see lots of info.
It's under the Battery on the passenger side (behind the wheel arch cover)
Not a big job but best handed to a Webasto professional after removing or contact Mike on rover 75 forum for circuitboard fix.
Good luck! Thumbs Up
Post #372644 16th Feb 2016 4:30pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Loads of info on here, I would search on here but also read the two threads below on the Rover 75 forum
First thing I would try is pulling fuse 59 in the passenger glove box for 30 secs (might be a diff fuse depending on your model and year, but details should be in the handbook) - the FBH can be locked out if it fails to operate correctly 3 times in succession, pulling fuse 59 should reset the lockout.
Then read the threads below to start problem solving!
http://www.the75andztclub.co.uk/forum/showthread.php?t=71982
http://www.the75andztclub.co.uk/forum/showthread.php?t=100297 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #372647 16th Feb 2016 4:50pm
dazk2001
United Kingdom 2008 Range Rover Vogue SE TDV8 Stornoway Grey
dolphinboy
how do you access the webasto can it be removed via the wheel arch or is it battery out
thanks 2008 Range Rover 3.6 TDV8 Vogue SE
Post #673551 17th Sep 2023 5:50am
Dolphinboy
via wheel arch. remove the liner Thumbs Up
Post #673563 17th Sep 2023 9:49am
