![]() | Home > Wheels & Tyres > Driving on a piste /off road on snow |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
as this is more related to tyres/wheels, i've moved the post here... ... - .- -.
| Bryn Member Since: 19 Jan 2016 Location: Midlands Posts: 13
Thank you! |
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1431
LR do an accessory snow traction system part no LR005737 for front wheel use with 20" wheels and chains part no VUJ000020 for rear wheel use on 18" and 19" wheels. I have the chains but as yet have not needed to fit them. You could also consider studded winter tyres, I recall a contributor from Moscow had fitted them. Only Range Rovers since 1988 |
Thanks CS, I'd seen and considered those. They don't list the 275 width I need, but I'm wondering whether I just gamble and hope they'll work.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
you may have 275/45s fitted but the correct size is 255/50 20 so you may find some suitable tyres in that size.
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136
Seems like an unusual requirement - are you sure it's a piste - generally they're not compacted enough to take the weight to a car on regular tyres.
Thanks guys,
| Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1123
Not sure which would be worse, gays on trays or a Full fat, suspect it would still be the snow boarders. letters not necessarily in the right order |
Well if I have anything to do with it, there will be both. So double the pain Dixy. |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
@Bryn
Absolutely, plans change fast but I'm sure there will be something interesting to show! |
Hi guys, as promised here is it what I needed to source tyres for. This was a project I produced for Jaguar in support of Graham Bell aiming to become the fastest man on skis.
Looks like fun |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
It looks like a summer mountain road covered in snow and used as a piste in winter. I was imagining an up/down wide piste. That looks like filming was a lot of fun. |
| All times are GMT |
