Home > Wheels & Tyres > Driving on a piste /off road on snow
Bryn
2002 Range Rover SE Td6 Buckingham Blue
Hi,
I've got quite a specific task coming up that I could use some advice on, if anybody has any relevant experience of.
I have a L322 TD6 fitted with 20x? BBS alloys, the tyres are 275/45 R20 General Grabbers. So they've got a bit of decent tread to them but not specifically designed for snow.
I have to drive up a piste in a ski resort at a decent speed and I'm thinking I need some additional grip, chain's don't seem to be available to fit those tyres, so wondered if anybody had a recommendation.
Maybe downsize to an 18in wheel and tyre combo? Tyre socks? I'm not a complete beginner on snow, but the last time I drove on a piste was in a jacked up RR Classic with a very aggressive tread pattern.
Oh and if anybody has a 322 roof crate style rack I'd be interested in that and underbody armour. I'll be posting in the wanted section about those too Very Happy
Post #372814 17th Feb 2016 7:16pm
as this is more related to tyres/wheels, i've moved the post here... ... - .- -.
Post #372815 17th Feb 2016 7:19pm
Bryn
Thank you!
Post #372817 17th Feb 2016 7:29pm
CS
LR do an accessory snow traction system part no LR005737 for front wheel use with 20" wheels and chains part no VUJ000020 for rear wheel use on 18" and 19" wheels. I have the chains but as yet have not needed to fit them. You could also consider studded winter tyres, I recall a contributor from Moscow had fitted them. Only Range Rovers since 1988
Post #372819 17th Feb 2016 7:40pm
Bryn
Thanks CS, I'd seen and considered those. They don't list the 275 width I need, but I'm wondering whether I just gamble and hope they'll work.
Studded tyres would be good, but I need to sort this in the next week and drive out there on whatever tyres I end up with, so the add on solution like you mention would probably be better.
Post #372826 17th Feb 2016 8:00pm
you may have 275/45s fitted but the correct size is 255/50 20 so you may find some suitable tyres in that size.
Chains are available in the size for your grabbers have a look here
http://www.snowchains.com/4x4-snow-chains/...izeId=2817
though it really depends on how fast you are planning to drive up the slopes as chains aren't recommended on any car at speeds over 30ish. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #372837 17th Feb 2016 8:47pm
Seems like an unusual requirement - are you sure it's a piste - generally they're not compacted enough to take the weight to a car on regular tyres.
For most of the roads round a resort, regular chains would be fine - winter tyres & chains would be even better.
Studded tyres are out as you're not allowed to drive on tarmac with them - so unless you're changing tyres/wheels when you get there.....
Post #372881 18th Feb 2016 7:06am
Bryn
Thanks guys,
Alistair - It's definitely a piste as we're renting it for something, you hit the nail on the head about the snow not being compacted enough. On the move I'm confident we'll be alright, it's just the initial part of any movement when it can dig in.
Northernmonkeyjones - Yup, I know my Grabbers are a bit wider, thanks for the link to those chains, I'm going to get a set of them!
And I'm getting three snow traction systems from Land Rover, that should work on the vehicles we'll be using. If this all comes off (there's a massive snow storm predicted for the day we're there), I'll post up the results with some pics Smile
Post #373054 19th Feb 2016 8:04am
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Not sure which would be worse, gays on trays or a Full fat, suspect it would still be the snow boarders. letters not necessarily in the right order
Post #373103 19th Feb 2016 11:56am
Bryn
Well if I have anything to do with it, there will be both. So double the pain Dixy.
Post #373114 19th Feb 2016 12:32pm
Dolphinboy
@Bryn
don't forget to send piccies!!
Post #373136 19th Feb 2016 4:01pm
Bryn
Absolutely, plans change fast but I'm sure there will be something interesting to show!
Post #373141 19th Feb 2016 4:09pm
Bryn
Hi guys, as promised here is it what I needed to source tyres for. This was a project I produced for Jaguar in support of Graham Bell aiming to become the fastest man on skis.
We cut a track through a snowy forest in Austria in the end, as the snow on the selected piste in France wasn't hard packed enough.
I left my RR on the 275/45x20 General Grabbers and they worked fine, 2500miles in total. Great trip!
Thanks again for all the advice.
Post #377978 17th Mar 2016 12:52pm
Looks like fun Thumbs Up
Post #377991 17th Mar 2016 2:00pm
It looks like a summer mountain road covered in snow and used as a piste in winter. I was imagining an up/down wide piste. That looks like filming was a lot of fun. Thumbs Up
Post #377992 17th Mar 2016 2:00pm
