![]() | Home > Maintenance & Mods (L322) > TDV8 EGR maintenance |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1831 ![]() ![]() |
Once you have gone to the extent of removing them, you will probably decide to replace them anyway.
Edfors Member Since: 26 Oct 2012 Location: Uppsala Posts: 168 ![]() ![]() ![]() |
Better to replace. Here's a how to I wrote earlier. |
austeve01 Member Since: 17 May 2015 Location: Flagstone, Qld Posts: 12 ![]() ![]() ![]() |
Thanks Mikey. Appreciate your candour. |
Thanks for your advice Edfors. Looks like replacement will be the go. Cheers |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Gday Steve
Hi Pete
Gday Steve
33sport Member Since: 24 Jul 2015 Location: kent Posts: 82 ![]() ![]() |
worth checking your hoses for splits, I had a crack in the offside plastic rocker cover which made the engine smoke, had it changed which was an expensive job, but now is perfect no smoke.
Hammer Member Since: 14 Oct 2012 Location: Perth Posts: 124 ![]() ![]() ![]() |
I'm sure some smoke is normal, most diesels do, it seems the key is to clean it out from time to time otherwise it builds up and blows out all the build up in the exhaust when you put your foot down to overtake on the freeway. I've notice in the country; put your boot into it and clean it out and it stays clean for a while. Anything to do with fitting dpfs to the later? Also the Intercooler hoses are crap, I've had new ones last only a year, you may think they are ok but they are not. Fit silicon hoses. I had to take the manifold off and fitted new hoses when refitted and I noticed the improvement straight away but I didn't seem to have any leaks prior, pitty can't get silicon hoses for the 4 short pipes on top. |
I'm interested in the answer to the question as well, can they be cleaned? And if so will they be restored back to normal operation?
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
To be totally honest there is no need to clean them as they do not get blocked up like on other cars. I have a couple of EGRs in the garage and they have a light coating soot but nothing like I have seen on other vehicles.
Thanks. I did replace the 2 top turbo hoses recently due to splits .. the 2nd one within three weeks of the first one. Improvement in performance was noticeable and of course no black smoke |
I'll give this a try. I agree with you re the intercooler hoses. Unfortunately for me on both occasions I was out in the sticks and local garages could only source parts from capital cities with a wait of up to two days! Phoned my workshop & they despatched genuine to me straight away. I have not found anyone local who stocks silicon which I would prefer. |
Thanks for that info. I'm impressed with removal of those EGRS in that time. |
