Home > LPG > Anyone run an 4.2sc on LPG here?
RR8701
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
Hi All,
I have a 4.2sc LPG available to me fitted with the prins systems
Have done a search on LPG for the RR 4.2sc and it seems to be ok if its been fitted correctly and by a reputable fitter.
I just want to make sure im not going into a known money pitt.
Anyone got any advise and experience of running one.
Post #357421 17th Nov 2015 5:01pm
n1cktdv8
A pal of mine bought one with the Prins system, he's been very pleased but in the summer if he drives it hard it gets very hot... Is this where I put the car details and a bit about myself ?........
Post #357424 17th Nov 2015 5:22pm
RR8701
hmmmm should it do that even if he drives it hard?
Post #357426 17th Nov 2015 5:27pm
dingg1
I have an lpg system in mine
some teething problems when first installed 2 years ago , no problems since
I have it set up to slipstream some petrol at >3500rpm and a valve saver system fitted as well.
if it hasn't got a valve saver system fitted I'd get a leakdown test done - in fact even it has, still gte a leak down test done before committing to buy
Post #357431 17th Nov 2015 5:45pm
n1cktdv8
I should explain really; I didn't mean like a bank robber ! He tows a pretty heavy boat and heads down to Spain each year, both times he's done that run it has become very hot. A combination of a heavy load, outdoor temp and longer driving spells have likely contributed as a combination. He's selling it now anyway and making his way to the heavy oil division with a 4.4 tdv8 ! Is this where I put the car details and a bit about myself ?........
Post #357433 17th Nov 2015 5:51pm
LPG burns about 10 degrees hotter than petrol, but seeing as they both burn around 1000 degrees it doesn't make much difference, it certainly won't be the LPG's fault it runs hotter unless it's been poorly set up and is running lean but that would usually put the MIL light on...
The S/C will run fine on LPG, as with any install, get it looked at by an LPGA approved installer, preferably someone who comes recommended... The install is only as good as the person who set it up...
It will be a bargain superFF for sure.... Thumbs Up Pete
-Click here for Thread-
Post #357434 17th Nov 2015 6:03pm
steptoe
I've a bmw engined 4.4 V8 with a Prins system. Never had any problems at all in the 3+ years and 35k miles i've owned it. It came with a certificate of installation.
No personal experience with the 4.2 engine but have read that it has softer valve seats and should have a valve lube system installed with the LPG.
Post #357440 17th Nov 2015 6:28pm
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
I have a 4.2 with the Prins system. I get it serviced regularly and have the lube system.
no problems to report about LPG...don't get me going about everything else
Post #357463 17th Nov 2015 8:28pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
I run my SC on LPG no problems, the car was converted before i bought it and has now covered 40000 on log with no problems. I have the Romano system which works really well, is setup to introduce petrol at high rpm as well.
Post #373593 22nd Feb 2016 7:19pm
Laurence82
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
4.2 2005 Supercharged
I have read that pre 2006 when they changed the supercharged engine to nickel the valves are hard....
Post #637146 17th Jul 2022 8:08pm
Yours, being a 2005 is one of the first S/C and could be a 2006 Model Year car... Thumbs Up Pete
Post #637161 17th Jul 2022 9:13pm
dingg1
Still here 7 years later running mine on lpg Cool no engine issues
Post #637166 17th Jul 2022 10:07pm
dingg1
Forgot to mention now slipstream of petrol at 2950 rpm, Im getting older and don't thrash it as much
Post #637167 17th Jul 2022 10:21pm
Laurence82
so was there a pre nickel engine that was less prone to valve damage? the guy I bought the car off said the LPG did feed some petrol in with the LPG I thought it was bogus so all good there if its a real thing. excellent.
anyone know a good LPG place to get a service northwest England Morecambe bay area or near? Very Happy
Post #637186 18th Jul 2022 8:20am
friskydog
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I run LPG after a rebuild I had done where I took all valve clearances when fixed....
Now its 25,000 miles later on LPG and I am taking the gas out as its seeing large VSR Valve Seat Recession. Please see link and picture below.
Hope you find it interesting.
So 25,000 miles later after shim/bucket engine rebuild on LPG on my Range Rover 4.2L L322 2007 Supercharged we have measured Valve Seat Recession. I have also completed a compression test to check pistons.
See attachment for measurements...
1. At rebuild stage
2. After approx. 25,000 miles run on LPG
3. I used Flashlube (Valvesaver)
I believe I will re-shim again however I have decided to remove the LPG buy new inlet manifolds and keep the car for as long as possible. Just thought those looking to LPG might find this data useful if making decisions on whether to adopt LPG. I have used a Prins VSI 2.0 system with auto valve dosser. @ £2500.
So even with the dosser we still see VSR Big Cry .
I just wish I knew why some have been fine with LPG and mine has not. I hear pre nickel engines alot but I don't know. I use a PRINS guy that gets flown all over the world fr installs so he's pretty damn good. So its baffling as to why mine has recessed so badly.
Never driven her hard on LPG
I turned button off whenever wanting to let her loose.
Never ran out of FLASHLUBE
Maintained LPG Servicing.
SO what is it that is so different to all your experiences?
Many Thanks.
https://drive.google.com/file/d/1wamSQeP-L...drive_link
 Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #715227 30th Mar 2025 10:39pm
