Home > Maintenance & Mods (L322) > BMW M62 4.4 engine on petrol and LPG Coolant pressue problem
fisha
That is an option to remove the stat, but its my personal opinion that the stat is in place to direct flow between the engine block and radiator . . . and that even when open it channels flow round the block. With no stat, that flow round the block is possibly not as good as it could be. Yes, the increased flow to the radiator will aid cooling of the fluid, but you need to be sure that cooled fluid is then getting directed through the block, which is why I leave the stat in.
As for multiple failures of the expansion bottle . . . yes, I had that. Came down to me buying pattern parts from online retailers. 1 even failed on the very first run. Bought genuine, and it was fine after that.
Also, the filling + bleeding process has to be carried out properly. I took my time with it, and that made a difference as well I think. V8 or else ...
Post #373738 23rd Feb 2016 7:26pm
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
Haylands, yes good suggestion.
I have researched quite a bit through the BMW forums and the LR ones too over the last week.
There really is an issue with the M62 engine set up in the FF and in the sedans it seems.
Why Land Rover never had to recal FFs and do something about this situation is crazy, this would be costing millions globally a year, there is an indy here in Sydney that regularly does engine rebuilds due to hose, expansion bottle failures..........women are particularly bad for continuing to drive after all the coolant has had a rapid decompression and left the building.
Not sure about your neighbourhood, but FF is the car of choice for women here 7/10 FFs are driven by women from my observations.
For my own peace of mind I just want to see something change here with the pressure and the temps with my having installed a new stat because I just dont see anything else "WRONG" with the cooling system.
The 88c mod most certainly looks a very sensible modification.
For a vehicle that is "supposed" to be very capable in remote areas (a joke) having a cooling system that operates in excess of 100c is insane there is not really any way you can patch things up and keep moving if you have a cooling system blow out some place.
36c here tomorrow that will test things.
Post #373781 23rd Feb 2016 10:08pm
The only reason they made it run so hot (it never was run hot in BMW cars) was to pass the new (at the time) emission regulations, it was an old engine then and couldn't make the mark on part throttle tests, so they cranked up the heat to burn off more fuel, it worked and we got the best engine (at the time) that was ever put into a Range Rover...
Look after them, lower the temp, change the oil a lot and they will last for ages....
Women tend to drive the RR Sport or Evoque round here.... Pete
-Click here for Thread-
Post #373790 23rd Feb 2016 10:30pm
johnboyairey
quote.... Women tend to drive the RR Sport or Evoque round here.... unquote
they do.. its the parking, and 'lipstick application at speed' that is lacking in the UK..
Post #373798 23rd Feb 2016 11:33pm
RR P38
OK,
Observations;
After installing a new thermostat.
We have had some pretty warm weather in Sydney last week and this.
On a 41c day in heavy slow moving traffic via the hidden menu in the message centre coolant temp runs between 108 & 110C even highway cruise at 110km/hr will still show 108c.
This is "NORMAL" operation............leaves me concerned, I shall be looking into a cooler running thermostat for sure.
Post #375442 3rd Mar 2016 8:52am
That's what mine ran at before, with the 80deg stat it runs around 90deg with no viscous fan, I have electric fans that I've set to cut in at 99deg... they only come on if you sit in traffic for a while...
Runs much better... Thumbs Up Pete
Post #375479 3rd Mar 2016 11:32am
p38arover
Australia
RR P38 wrote:
OK,
Observations;
I'll have to find that setting. Do I need to use the IID tool for that?
I did a run in to Sydney tonight. On the M4 the car ran at 99 deg C according to ScanGuage. In traffic on Parramatta Rd, it would rise to about 102-103 but drop back to 101 once I was moving. Back on the M4, it was back to 99. Outside temp was 30 deg C.
I think I'll change thermostats. On my GEMS P38A, I fitted a cooler (82 deg C) thermostat into the inlet manifold and replaced the original thermostat housing with a fabricated empty "sputnik" I bought from Davis Performance landys. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #376307 8th Mar 2016 12:39pm
RR P38
Just push the right hand button on the message centre, hold it down until the display changes to nr.........
once it comes up push it until you get to seven...............and push the left hand button once to access the coolant temp.
Post #376444 8th Mar 2016 10:36pm
p38arover
Australia
I shall go and look! Smile Thanks. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #376459 9th Mar 2016 1:09am
p38arover
Australia
Just tried it.
I pressed the RH button until Test-NR 01 came up. Continued pressing until Nr. 7 appeared, pressed the LH button and got Lock On.
Dunno what that means. If I continued pressing the LH button the Lock no. incremented. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #376460 9th Mar 2016 1:19am
RR P38
Sorry Ron, forgot to unlock first, once you have done this the menu stays open.
It sound long winded but its a good thing once you have it open.
I had to subtract 1 to get this too work, but not everyone has too.
All test functions, with the exception of tests No's. 1 and 2, are locked after the instrument pack is reset and must be
unlocked using test No. 19. This locking feature is intended to make instrument pack test functions difficult for
unauthorised persons to access. Refer to function test No. 19 for further detail
TEST 19
The unlock code is known as a checksum of the VIN. The VIN can be obtained from Test Function No. 1. The
numbers of the VIN are added together and the resulting figure equals the checksum. For example, if the VIN is
XA37295 the checksum will equal 26, which in turn equals the unlock code.
Enter the unlock as follows:
lWhen test function No. 19 is entered, 'LOCK : ON' is displayed
lPress the trip reset button once, 'LOCK : 00' is displayed
lPress the trip reset button until the unlock checksum is reached, i.e. 26
lPress the check control button once, all test functions will be unlocked.
NOTE: All test functions will remain unlocked, even when the ignition is switched off.
lRelock the test functions as follows:
lGo to test function No. 19 and press the trip reset button, 'LOCK : OFF' is displayed
lPress the trip reset button a second time, 'LOCK : ON' is displayed
lPress the check control button or switch the ignition off to relock the test functions.
Post #376467 9th Mar 2016 3:44am
p38arover
Australia
Thank you. Yes, I tried the checksum but it didn't work until reduced the number by 1 as you suggested. Unfortunately, the pixel problem makes reading the text difficult. I have a new ribbon cable but have yet to try fitting it.
On the upside, the coolant temp as shown in the Message Centre is the same as shown by the Scan Gauge.
The L322 message centre is pretty poor compared to the P38A.
With Test Nr. 2 I can see the service indicator light is working - just. I haven't looked into the instrument panel lighting yet. I would also like to do something about the dim back lighting on the controls in the central section of the dash. Yes, it is turned up to maximum. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #376472 9th Mar 2016 7:14am
