![]() | Home > Maintenance & Mods (L322) > Minor change, big improvement IMO |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 ![]() ![]() ![]() |
I don't use the front cigarette socket much for anything else than to plug in a small USB socket. Lately I noticed the sigarette socket came partly out when I remove the USB socket. I always remove the USB socket when I don't use it because I don't like the look of it.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
good job.. i've put the usual belkin type usb adapter in mine .. ... - .- -.
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
I like that. Very neat. Presume it has a current converter built in? 2007 Vogue TDV8 with 255/55/20's fitted |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
looks good but not sure i like the blue lights, is it not distracting at night, would have been better with orange lights to match everything else. |
Not sure about the built in current convertor.... Maybe eBay page will tell you more about that...
Is yours a permanent socket or one where it has an almost-flush push in adaptor like this:- ?
The permanent one jonny |
Very easy.
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183 ![]() ![]() ![]() |
ok thank you very much!
Very easy to remove.
thank you very much! |
Markjohns1 Member Since: 17 Jan 2016 Location: Cheadle hulme Posts: 139 ![]() ![]() |
Managed to remove cigarette lighter and disconnect,however cant see how the round rubber seal surrounding the hole over the console comes off ,,any ideas. |
not sure what you're talking about... Did you remove the complete cigarette socket by the two screws from the underside? I had to widen the hole for the USB socket to fit. 2002 L322 V8 |
Haha thankyou ,will widen hole |
