Home > Maintenance & Mods (L322) > Minor change, big improvement IMO
pietertje
Netherlands 2002 Range Rover Vogue 4.4 V8 Java Black
I don't use the front cigarette socket much for anything else than to plug in a small USB socket. Lately I noticed the sigarette socket came partly out when I remove the USB socket. I always remove the USB socket when I don't use it because I don't like the look of it.
So I decided to fit a perment USB socket in there. (something like this: http://www.ebay.com/itm/12V-Dual-USB-Car-C...1367336173)
It was an almost perfect fit (had to make the original hole for the socket a little bit bigger).
This was the result:
(sorry, not able to rotate the images) 2002 L322 V8
Post #373863 24th Feb 2016 11:09am
good job.. i've put the usual belkin type usb adapter in mine .. ... - .- -.
Post #373866 24th Feb 2016 11:15am
jonnyboy54321
I like that. Very neat. Presume it has a current converter built in? 2007 Vogue TDV8 with 255/55/20's fitted
Post #373868 24th Feb 2016 11:20am
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
looks good but not sure i like the blue lights, is it not distracting at night, would have been better with orange lights to match everything else.
Post #373869 24th Feb 2016 11:21am
pietertje
Not sure about the built in current convertor.... Maybe eBay page will tell you more about that...
Agree on the blue lights. The one eBay page mentioned before has less blue, since it doesn't have the blue lighted ring.
They are not to distracting at night though. But if i could swap for orange/white/green I would. 2002 L322 V8
Post #373872 24th Feb 2016 11:26am
jonnyboy54321
Is yours a permanent socket or one where it has an almost-flush push in adaptor like this:- ?
http://www.ebay.co.uk/itm/DC12V-24V-Car-Ci...Sw9r1WCg17 2007 Vogue TDV8 with 255/55/20's fitted
Post #373920 24th Feb 2016 3:50pm
pietertje
The permanent one jonny Thumbs Up 2002 L322 V8
Post #373921 24th Feb 2016 3:52pm
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
can you remove the original socket easily?
i'm asking because the one in my dad's td6 is corroded and needs to be replaced.
(he accidentally had the sunroof open some times when we had rain in summer Sad )
the corrosion was the fault of battery drain, we thought it was the havac unit Laughing
Post #373922 24th Feb 2016 4:00pm
pietertje
Very easy.
Only 2 small screws hold in place. You can swap it for a usb one or just put a new one in place:
Order here: http://www.ebay.co.uk/itm/Range-Rover-L322...1680761049 2002 L322 V8
Post #373923 24th Feb 2016 4:07pm
clemenz
ok thank you very much!
and what about the cover? can you remove that easy?
Post #373924 24th Feb 2016 4:14pm
pietertje
Very easy to remove.
Instructions here:https://www.youtube.com/watch?v=X2SDrtrEjV4 2002 L322 V8
Post #373997 24th Feb 2016 9:28pm
clemenz
Post #374230 26th Feb 2016 12:41am
Markjohns1
Managed to remove cigarette lighter and disconnect,however cant see how the round rubber seal surrounding the hole over the console comes off ,,any ideas.
Post #374559 27th Feb 2016 6:48pm
pietertje
not sure what you're talking about... Did you remove the complete cigarette socket by the two screws from the underside? I had to widen the hole for the USB socket to fit. 2002 L322 V8
Post #374560 27th Feb 2016 7:30pm
Markjohns1
Haha thankyou ,will widen hole
Post #374705 28th Feb 2016 4:53pm
