Home > Maintenance & Mods (L322) > jacking woes - alternative locations or jack suggestions?
mat777
United Kingdom 2005 Range Rover Vogue 4.4 V8 Giverny Green
Hi all,
I attempted to jack up my FF using the sill points the other day to rotate the tyres. Even using a massive trolley jack borrowed from my neighbour, the jack ran out of travel before the suspension did, and it was trying to roll across the floor as the height meant the weight was now pressing on it at an angle, which was in my mind an unsafe situation.
Is it possible to jack the suspension arms/spring bottom mounts at all or does the car have to be jacked from the sill?
If so, can anyone please recommend a high-lift bottle jack capable of overcoming the suspension travel (especially at the rear)?
Thanks,
Matt NW060
"Red Shed" - 1982 Series 3 88" County Station Wagon
"Spirit of Great Britain" - Rolls Royce Meteor V12 engine
ZG875 - Westland Sea King (cockpit section)
"Carly Rae Jeepsen" - 2006 Jeep Commander 5.7 Hemi
"Pride Of The Road" - 1/4-scale Marshall traction engine - sold
"Georgina" - 2000 Discovery 2 TD5 ES - sold
"Windsor" - 2005 Range Rover Vogue 4.4 - dead
Post #373887 24th Feb 2016 11:54am
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
I'm starting to wonder about one of those airbag type jacks, the sort you pump up from your exhaust.
Post #373888 24th Feb 2016 11:59am
steptoe
I've lifted my car plenty of times under the suspension arms without any problems.
Post #373895 24th Feb 2016 12:29pm
clarkie
England 2005 Range Rover Vogue Td6 Adriatic Blue
what you need is a merc sprinter van bottle jack i use one on mine without any problems
Post #373927 24th Feb 2016 5:08pm
i to use a trolley jack under the suspension arms, front and rear.... ... - .- -.
Post #373929 24th Feb 2016 5:17pm
mzplcg
^ +1. The suspension arm is the place to jack from.
Post #373931 24th Feb 2016 5:20pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Trolley jack and a block of wood to spread the load on the suspension arms Thumbs Up Mine was a blue one! Smile
Post #373933 24th Feb 2016 5:20pm
mat777
Thanks chaps,
A quick google suggests that the place to do it is where the arm pivots on the subframe, like so?
 NW060
Post #374013 24th Feb 2016 10:33pm
mike whiskey
United Kingdom 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
I would use the point your picture shows, or the point on the suspension arm under the upright, since that point carries the weight of the car in normal use.
MW Car history includes: LR Series 3, RR Classic x 4, LR 101, Discovery 1 and 2, FFRR. D3, Freelander 2 and now back in FFRR.
Yes I'm a masochist....
Post #374058 25th Feb 2016 9:54am
steptoe
Unnecessary quote removed
You'll still have the same problem of the arm distending the suspension fully and running out of jack height.
I use the point hearer ther wheel so the suspension keeps the car supported. And as mentioned by others, a piece of wood to spread the load.
Post #374089 25th Feb 2016 12:57pm
Weegie
The workshop manual gives these jacking points:
http://workshop-manuals.com/landrover/l322...g/lifting/
Using a 3 ton trolley jack I have comfortably lifted both front wheels off the ground. Then used axle stands. Very convenient when doing both front suspension arms.
Haven't used the rear point (next page) but the pad on my trolley jack looks a bit wide to pass between the two exhaust branches. I suspect that a suitable sized block between the jack and the jacking point will do the trick. Will try it when I get round to checking handbrake shoes. John
GAP iiD BT-Sold
Post #374102 25th Feb 2016 2:43pm
