![]() | Home > Maintenance & Mods (L322) > jacking woes - alternative locations or jack suggestions? |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 794 ![]() ![]() ![]() |
I'm starting to wonder about one of those airbag type jacks, the sort you pump up from your exhaust. |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
I've lifted my car plenty of times under the suspension arms without any problems. |
clarkie Member Since: 26 Aug 2013 Location: leicester Posts: 51 ![]() ![]() ![]() |
what you need is a merc sprinter van bottle jack i use one on mine without any problems |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35790 ![]() ![]() |
i to use a trolley jack under the suspension arms, front and rear.... ... - .- -.
^ +1. The suspension arm is the place to jack from. |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Trolley jack and a block of wood to spread the load on the suspension arms |
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 ![]() ![]() ![]() |
Thanks chaps,
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 117 ![]() ![]() ![]() |
I would use the point your picture shows, or the point on the suspension arm under the upright, since that point carries the weight of the car in normal use.
Unnecessary quote removed
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3269 ![]() ![]() ![]() |
The workshop manual gives these jacking points:
