Home > Technical (L322) > Changed spark plugs... But one...
Page 2 of 4 <1234>
pietertje
Netherlands 2002 Range Rover Vogue 4.4 V8 Java Black
Could be, but then I'd expect this coil wouldn't fit properly. 2002 L322 V8
Post #374008 24th Feb 2016 9:58pm
Declan303
Ireland 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Drop the socket down on the plug without the extension bar and through the hole where the extension bar goes, determine how deep it is going onto the plug. Compare that to one of the good plugs that you removed. If its going down same distance then you need a tighter socket on it to grip it.
Post #374011 24th Feb 2016 10:10pm
jonnyboy54321
Having looked at this for the third time, I think what you need is something like some uber uber long needle nose pliers, or perhaps a very small right angled pointed pick with a long handle.
[url]http://www.ebay.co.uk/itm/Ullman-8pc-Hook-Pick-Set-9-in-Long-Straight-Right-Angle-Complex-USA-MADE-CHP8-L-/141675714389?hash=item20fc87d755:g:bTYAAOSw3xJVYiYE
something like this perhaps? or two, one at each side?
Patience and a gentle touch will be the key with this.
Or...........a length of thin fishing line. Long loop. Pushed down pass the offender, then, with a tool, ease it around so that it ends up sliding towards the electrode when you put tension on both sides of the line, a sharp pull on both ends (wrap around a scrap timber/screwdriver so you dont chop a finger off !!).[/url] 2007 Vogue TDV8 with 255/55/20's fitted
Post #374024 24th Feb 2016 11:19pm
I wonder if it's one of these
Is there one missing on your cam covers...??
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #374039 25th Feb 2016 12:47am
pietertje
Thanks Jonny (and others for thinking with me)!
I also ordered the pick set you recommended (on top of the irwin extractor), seems to me these suggestions are the safest to apply for now. Will let you guys know the outcome. 2002 L322 V8
Post #374238 26th Feb 2016 4:13am
holidaychicken
That's exactly what I was thinking, that is the aluminium spacer from one of the two bolts on the plastic cover in which case I would spray some brake cleaner on it and put a small amount of araldite on the end of a socket and try and glue the socket to it. Either that or maybe one of the washers from under the cam cover bolts
The oil leak mentioned is not head gasket but cam cover gasket.most likely
This is what it should look like
Post #374242 26th Feb 2016 6:48am
Whatever was the outcome on this one? .
Post #378042 17th Mar 2016 7:34pm
pietertje
Still no luck m8!
Tried last weekend with the pick tools Johnyboy suggested... It doesn't seem to move at all... Made Some additional photo's while I was there....
Don't think I Will resolve this anytime soon... Maybe when I replace rocker cover gaskets..... 2002 L322 V8
Post #378077 17th Mar 2016 10:01pm
pietertje
[removed]
sorry.. double post 2002 L322 V8
Post #378078 17th Mar 2016 10:01pm
johnboyairey
My money is it was one of the stepped waters from the rocker cover. And he got it off with a magnet, or some long nosed pliers. Changed the plug, and has been out driving and enjoying himself so much, he forgot to follow the thread, and put us out of our misery.
he can't have driven it like it before, it must have been waiting to fall perfectly, as he took off the coil pack.
Oh the joys of car mechanics!
Post #378079 17th Mar 2016 10:06pm
pietertje
Wish that was true.... 2002 L322 V8
Post #378080 17th Mar 2016 10:12pm
Have you tried unscrewing the top of the spark plug - maybe it is fixed to that? .
Post #378081 17th Mar 2016 10:29pm
pietertje
Nope haven't tried, the only top of the spark plug visible is the ceramic part and the metal head... I'm afraid of breaking it... 2002 L322 V8
Post #378082 17th Mar 2016 10:31pm
holidaychicken
You could try a ring magnet if its steel if you can find one that is the right internal and external size but make sure you have something connected to the magnet else that might get stuck down there also, if not put some araldite around the end of the spark plug socket after degreasing the bore and socket and glue whatever it is to the end of the socket but make sure you dont use too much and glue it to the spark plug. if it wont shift the glue will break off leaving whatever it is behind providing you can pull on the socket.
http://www.ebay.co.uk/itm/All-Sizes-Quanti...rkt%3D1%26
Post #378083 17th Mar 2016 10:40pm
johnboyairey
Have you tried one of those grabbing tools you see in accessory shops? A sort or bendy stick, with four talons, up a tube, you push on the thumb button, and four claws come out, and gently released, grab the object you want to acquire.
Just search for claw pick up tool
You can also magnetise a deep socket by repeatedly stroking in long circular strokes over and old speaker magnet.
Post #378086 17th Mar 2016 11:13pm
Page 2 of 4 <1234>
