![]() | Home > Technical (L322) > Changed spark plugs... But one... |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 ![]() ![]() ![]() |
Could be, but then I'd expect this coil wouldn't fit properly. 2002 L322 V8 |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
Having looked at this for the third time, I think what you need is something like some uber uber long needle nose pliers, or perhaps a very small right angled pointed pick with a long handle.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8701 ![]() ![]() ![]() |
I wonder if it's one of these
Thanks Jonny (and others for thinking with me)!
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
That's exactly what I was thinking, that is the aluminium spacer from one of the two bolts on the plastic cover in which case I would spray some brake cleaner on it and put a small amount of araldite on the end of a socket and try and glue the socket to it. Either that or maybe one of the washers from under the cam cover bolts
The oil leak mentioned is not head gasket but cam cover gasket.most likely This is what it should look like
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Whatever was the outcome on this one? .
Still no luck m8!
[removed]
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
My money is it was one of the stepped waters from the rocker cover. And he got it off with a magnet, or some long nosed pliers. Changed the plug, and has been out driving and enjoying himself so much, he forgot to follow the thread, and put us out of our misery.
Wish that was true.... 2002 L322 V8 |
Have you tried unscrewing the top of the spark plug - maybe it is fixed to that? .
Nope haven't tried, the only top of the spark plug visible is the ceramic part and the metal head... I'm afraid of breaking it... 2002 L322 V8 |
You could try a ring magnet if its steel if you can find one that is the right internal and external size but make sure you have something connected to the magnet else that might get stuck down there also, if not put some araldite around the end of the spark plug socket after degreasing the bore and socket and glue whatever it is to the end of the socket but make sure you dont use too much and glue it to the spark plug. if it wont shift the glue will break off leaving whatever it is behind providing you can pull on the socket.
Have you tried one of those grabbing tools you see in accessory shops? A sort or bendy stick, with four talons, up a tube, you push on the thumb button, and four claws come out, and gently released, grab the object you want to acquire.
