![]() | Home > Technical (L322) > EAS woes! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
i believe delphi are OE for FF struts.. ... - .- -.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Definitely Delphi. Slightly dearer than the option but good quality OE.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8713 ![]() ![]() ![]() |
Mine had Dunlops on when I bought it, they had nearly three inches less travel than the Delphi ones I replaced them with after one went bang....
Steadfast Member Since: 20 Nov 2015 Location: Devon Posts: 26 ![]() ![]() ![]() |
Lovely job, thanks chaps. I'll get some ordered.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
No reason for any errors, should just fill up and work, as long as you ensure the height sensors aren't disturbed in any way. .
Happy days,
Start spraying the two nuts and bolts that hold the strut on at the bottom with some penetrating fluid and do it daily, then try to crack them off a couple of days before you change the struts... You can get to them with the wheel on full lock and your head in the wheel arch... |
Many thanks Pete,
The other thing about the bolts is that they have lateral grooves running their length (mine did anyway) so not easy to find lying about.
Yep, sure are tight, I had an HGV 1" drive rattle gun on them... three moved, one snapped.... Pete
I used a 16" breaker bar and two lengths of trampoline leg for leverage (@ 5ft in all) then all my weight (11stone) on the end. That got them turning |
Jesus! Sounds like I'm going to need back up on this one then!!! |
My biggest problem was getting the bolts out after loosening the nuts. However, the nuts weren't a walk in the park either. To give you an idea the torque setting for them is 250nm. Bad enough when new and clean but worse when in for several years.
Well, you guys were all correct. What utter b*****ds they were to get out. All done now, but not before much swearing and perspiration to get them out. Mate popped his compressor over and air gun in the end.
