Home > Technical (L322) > EAS woes!
Steadfast
United Kingdom 2003 Range Rover Vogue 4.4 V8 Oslo Blue
EAS woes!
Evening all
Are Delphi front struts ok? Had an air bag go front drivers side, going to do both fronts anyway. But not keen on LR genuine prices.
Thanks for any opinions
Steady
Post #374160 25th Feb 2016 8:26pm
i believe delphi are OE for FF struts.. ... - .- -.
Post #374171 25th Feb 2016 9:03pm
Weegie
Definitely Delphi. Slightly dearer than the option but good quality OE.
http://www.island-4x4.co.uk/suspension-par..._2837.html
Other suppliers available John
GAP iiD BT-Sold
Post #374175 25th Feb 2016 9:09pm
Mine had Dunlops on when I bought it, they had nearly three inches less travel than the Delphi ones I replaced them with after one went bang....
I know they were a few years old when I took them off but they just didn't look as good as Delphis... Pete
Post #374176 25th Feb 2016 9:14pm
Steadfast
Lovely job, thanks chaps. I'll get some ordered.
Is there likely to be any issues with errors when I have got them on? Am I going to need to reset anything do you think?
Steady
Post #374182 25th Feb 2016 9:55pm
No reason for any errors, should just fill up and work, as long as you ensure the height sensors aren't disturbed in any way. .
Post #374192 25th Feb 2016 10:35pm
Steadfast
Happy days,
Again, many thanks for the replies. Appreciated greatly.
Steady
Post #374217 25th Feb 2016 11:22pm
Start spraying the two nuts and bolts that hold the strut on at the bottom with some penetrating fluid and do it daily, then try to crack them off a couple of days before you change the struts... You can get to them with the wheel on full lock and your head in the wheel arch... Thumbs Up
One of mine sheared off rather than undid..... they are pretty big so I doubt you'll find something lying around that would do.... Pete
Post #374221 25th Feb 2016 11:59pm
Steadfast
Many thanks Pete,
Been out this morning and give them a good dose of Wurth penetrating fluid, looking to do them tomorrow morning.
Steady
Post #374299 26th Feb 2016 2:17pm
Weegie
The other thing about the bolts is that they have lateral grooves running their length (mine did anyway) so not easy to find lying about.
I did all the squirting with lubricant etc but in the end had to get MOH holding it on full lock whilst I welted them with a sledgehammer. Needed her there as when the engine is switched off the wheel tends to centre and the clearance is needed to avoid hitting the wheel arch.
Hope you don't have the same problem Thumbs Up I fitted the Delphi in December last and they are excellent.
Good luck. Thumbs Up John
GAP iiD BT-Sold
Post #374314 26th Feb 2016 3:22pm
Yep, sure are tight, I had an HGV 1" drive rattle gun on them... three moved, one snapped.... Pete
Post #374315 26th Feb 2016 3:33pm
I used a 16" breaker bar and two lengths of trampoline leg for leverage (@ 5ft in all) then all my weight (11stone) on the end. That got them turning Smile .
Post #374357 26th Feb 2016 7:23pm
Steadfast
Jesus! Sounds like I'm going to need back up on this one then!!!
Post #374378 26th Feb 2016 8:06pm
Weegie
My biggest problem was getting the bolts out after loosening the nuts. However, the nuts weren't a walk in the park either. To give you an idea the torque setting for them is 250nm. Bad enough when new and clean but worse when in for several years.
Great satisfaction when the job's done.
Bet yours slide out without a hitch. Thumbs Up John
GAP iiD BT-Sold
Post #374404 26th Feb 2016 9:37pm
Steadfast
Well, you guys were all correct. What utter b*****ds they were to get out. All done now, but not before much swearing and perspiration to get them out. Mate popped his compressor over and air gun in the end.
Thanks for all the replies.
Steady
Post #374728 28th Feb 2016 6:43pm
