Home > Maintenance & Mods (L322) > Td6 high pressure pump replacement Allen key size?
Dr Meat
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Hi all
Could anyone advise me what size Allen key(19mm possibly) is required to remove the cap from the timing chain cover on the TD6 to gain access to the high pressure pump pulley.
Thanks in advance Thumbs Up
Post #371734 10th Feb 2016 9:35pm
Dr Meat
Turns out it is 17mm, new pump fitted Thumbs Up
Post #373248 20th Feb 2016 11:12am
reidy99
England 2003 Range Rover Vogue Td6 Oslo Blue
was this an easy replacement as mine is leaking around that area so i think i need to replace it?
Post #374567 27th Feb 2016 8:07pm
Dr Meat
Yes as long as you have the correct tool to lock the fuel pump pulley in place
Post #374700 28th Feb 2016 4:25pm
