![]() | Home > Maintenance & Mods (L322) > 2007 3.6 TDV8 Thermostat housing Replacement |
| vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332
I was going to do a detailed post about the very same job that I have just done, but for some reason all but one photo is on my phone.
| Hammer Member Since: 14 Oct 2012 Location: Perth Posts: 124
That's great
Hi Steve, any others gaskets/parts you think I should order for this job other than the thermostat housing and elbows.
There is a whole rake of gaskets that you could order, egr gaskets mainly, but I didn't bother.
Looks like it is starting to let go on that welded seam.
Good Steve,
| proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452
Paul,
Bloody good, check out this write up.
I did say in another thread that they would be good |
| Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204
i had mine done last year as it was cracked by my mate took him a few days and did a few other bits while stripped |
That looked to be leaking worse than ours seeing all that crud around the oil filter housing.
It's possible there was more than one leak, I dis had a slow leak for over year which I couldn't find as I'd say as it leaked the heat from the engine evaporated the water leaving the coolant deposits. When it got worse that may have been the original leak or maybe a second leak. With the second leak sometimes I could see coolant under the car.
| All times are GMT |
