![]() | Home > Maintenance & Mods (L322) > Alarm keeps going off - neighbours not happy |
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383
If its anything to do with the bonnet switch then just unplug it. I did with mine, it's not gone off mysteriously since. Discovery 4 HSE
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Isn't the beep when something inside the car sets it off, and the horn when something outside sets it off?
| Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395
Had a new bonnet switch fitted to mine - quick job, no more problems 2005 L322 Vogue Gold gone
| ruffy Member Since: 11 Jan 2016 Location: North Yorkshire Posts: 70
Thanks for the suggestions. Don't think it's the bonnet switch as it is disconnected. There is nothing moving inside the car either. A mystery! 1982 SIII 88” diesel
| rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296
had a spider in mine set it off 2007 tdv8 se ,stornaway grey |
The door latches contain the alarm microswitches, if they are getting wet? That might be your issue??? I would spray some WD40 in each and then open and close the doors a dozen or so times before finally slamming each door hard... Try that? And at least it it does not work! Your neighbour will not think your lazy! |
Thanks Craig, I will give that a go in the morning. 1982 SIII 88” diesel
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136
Try locking it with a different key fob - we had a weird problem with ours where one fob would lock it OK, but the alarm would go off regularly - the other was fine - I since replaced the faulty fob & have had no issues since. |
Thanks, will try that too! Craig, which bit of the door latches specifically need spraying with WD40? 1982 SIII 88” diesel
Its not scientific Im afraid Ruffy i would spray in the latch plate striker hole liberally sir |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
If that doesn't sort it, there could be a broken wire(s) in the door loom, I'm not familiar with the door switch operation, as to whether they are switching to live or earth, if they switch to earth then a single wire could be causing the fault. Yesterday I couldn't spell Engineer... Today I are one!
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
does anyone know where the chirper is, as I had a few nightime false alarms, and wondered if I could tape over it, so its not quite so noisy. (2002 petrol) |
RHS rear quarter from memory?????
They are usually switched to earth Miggit, that way when the car goes to sleep it does not affect battery life sir |
| All times are GMT |
