![]() | Home > Maintenance & Mods (L322) > Alarm keeps going off - neighbours not happy |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
So we are saying that they are, all be it rather fancy, the same as the old fashioned plungers, and they switch to earth when the door is opened...... so as you have said the most likely cause is the switch is full of water |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16343 ![]() ![]() ![]() |
Oh certainly could yes Miggit |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8643 ![]() ![]() ![]() |
Mine wouldn't shut up when I drowned the car, can't understand why... |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
Hi,
ruffy Member Since: 11 Jan 2016 Location: North Yorkshire Posts: 70 ![]() ![]() |
Well, so far so good. at about 8.30 this morning I gave the bonnet switch a good dose of WD40 and reconnected it. I then followed Craig's advice and gave each latch including the tailgate a generous splash of WD40, opened and closed the doors several times then gave each a good slam. I locked the car with the same fob (wanting to eliminate possible causes). After 2 and a half hours not a peep (or beep)! Not satisfied with this I gave the car a good soaking with the hose to simulate washing and locked it again. Here I am more than 5 hours later and still no alarm going off! Fingers crossed this is the end of the problem, at least for now, and my neighbours can get a good night's sleep. Thanks all for your help. 1982 SIII 88” diesel
Spoke too soon, the |
When are you lot going to learn, Range Rovers Do Not Like Water....Full stop |
I would be inclined to tape up the internal volumetric sensor outlets and see what happens. |
Or turn them off with the key fob |
Is there a way to disconnect the |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
Pull the fuse |
Pete (Haylands) kept his in his tool box, so they must be detachable, the next time it goes off, in about 10 minutes |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35709 ![]() ![]() |
pretty sure the siren is in the top left corner of the engine bay as you sptand in front of it.. ... - .- -.
