Home > Technical (L322) > windows /sunroof/opening overnight
handyM
England 2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi
I am new to the site , bought a 2003 4.4 Vogue and so far apart from rear wiper motor it has been fine, I have had this problem twice now
got up this morning to go to work all windows were down and sunroof partly open
and it has rained in any suggestions
I managed to get windows up using remote but not working on door switches as these need to dry out.
Post #375049 1st Mar 2016 10:12am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
You don't say whether the car was still locked or unlocked.
If you press and hold unlock the windows and sunroof open.
Dodgy remote or something pressing on remote?
Ian
Post #375058 1st Mar 2016 10:35am
handyM
Thanks for the reply Ianv8
The car was locked with the remote and the keys were put away, not in my pocket
just wondering if it is something to do with lazy locking?
Post #375059 1st Mar 2016 10:41am
If the key is getting worn it takes very little pressure to activate the Lazy Locking, and the key range is massive so easy to do when in the house... happened to mine with the old key, never happened with the new key.....
You can get it switched off by a dealer or get an IID tool and do it yourself... Thumbs Up Thumbs Up Pete
Post #375065 1st Mar 2016 10:59am
handyM
Thanks for the reply Pete
The key fob is a new one and the buttons seem ok
I can not understand how it is happening as I put the keys away in a safe
Place over night so they are not in my pocket and the spare fob is ok
I have now got to solve how to dry out drivers door switch panel as nothing
Seems to work on it except the rear windows isolating switch light is on
sunroof is now ok and works on its switch
Merv
Post #375069 1st Mar 2016 11:13am
if its a new fob then i suspect its been assembled incorrectly... ... - .- -.
Post #375071 1st Mar 2016 11:21am
Suggs
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
Is it only happening over night, what about if its left locked all day does it still happen, im wondering if it could some how be getting activated by another remote from someone else...
Post #375074 1st Mar 2016 11:31am
Merv, first you are lucky it's rain water, it should dry without leaving any deposits on the PCB which causes faults, you will need to get the door panel off and remove the switch panel, leave it in the airing cupboard over night should do it...
If you leave it on the water will eventually dry out but it will take a while and could cause lasting damage...
plenty of "how to's" on youtube, no special tools required...
I'd get the Lazy locking switched off if I were you... Thumbs Up Pete
Post #375078 1st Mar 2016 11:58am
handyM
Thanks Pete
will do that
Merv
Post #375080 1st Mar 2016 12:02pm
handyM
Hi Suggs
Yes its only happening overnight I will get the lazy locking switched off as Pete suggest
Thanks
Merv
Post #375081 1st Mar 2016 12:07pm
