Home > Wheels & Tyres > Range Rover sport 20inch wheels on a l322
Coconut
United Kingdom 2003 Range Rover HSE Td6 Barolo Black
Hi
Have been offered a set of 20 inch Range Rover sport wheels with 275 40 20 tyres.
I wondered if these would fit an 03 Range Rover l322?
Post #375130 1st Mar 2016 6:50pm
yes they will with the newer 23mm shank nuts but the tyre size is wrong.. ... - .- -.
Post #375136 1st Mar 2016 7:02pm
Coconut
Could you advise as to the correct tyre size.
Thank you
Post #375137 1st Mar 2016 7:06pm
because of the 9.5j wide sport rim you need 275 45 20 size tyres... ... - .- -.
Post #375140 1st Mar 2016 7:10pm
Coconut
Thank you
Post #375145 1st Mar 2016 7:25pm
jonnyboy54321
I'm sure the wheels I have for sale are off a sport but are 8.5J ? Must check. 2007 Vogue TDV8 with 255/55/20's fitted
Post #375206 1st Mar 2016 10:11pm
^ they are 8.5j but they are from the new L494 sport and not the older sports.. ... - .- -.
Post #375208 1st Mar 2016 10:14pm
jonnyboy54321
Thanks Stan 2007 Vogue TDV8 with 255/55/20's fitted
Post #375214 1st Mar 2016 10:28pm
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
Fitted my old L322 with sport wheels but had to change the tyres to 275/45/20s. The standard sport tyres (275 40s) were only rated at 106 and looked tiny on the L322. Have now got the same sport wheels on my disco Thumbs Up
Paul Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #386778 12th May 2016 10:16pm
Danwilderspin
hi guys i have stormers off a sport (20s) 275 40 19 - they look a little small but seem to drive fine are you saying they are dangerous with these tyres and i quickly need to change to 45s? i checked the weight between ff and sport and its only 100 kg - 25kg per wheel and i never run fully laden
Post #395752 12th Jul 2016 9:21pm
