![]() | Home > Wheels & Tyres > Range Rover sport 20inch wheels on a l322 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
yes they will with the newer 23mm shank nuts but the tyre size is wrong.. ... - .- -.
Coconut Member Since: 12 Feb 2016 Location: Watford Posts: 36 ![]() ![]() ![]() |
Could you advise as to the correct tyre size.
because of the 9.5j wide sport rim you need 275 45 20 size tyres... ... - .- -.
Thank you |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
I'm sure the wheels I have for sale are off a sport but are 8.5J ? Must check. 2007 Vogue TDV8 with 255/55/20's fitted |
^ they are 8.5j but they are from the new L494 sport and not the older sports.. ... - .- -.
Thanks Stan 2007 Vogue TDV8 with 255/55/20's fitted |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 ![]() ![]() ![]() |
Fitted my old L322 with sport wheels but had to change the tyres to 275/45/20s. The standard sport tyres (275 40s) were only rated at 106 and looked tiny on the L322. Have now got the same sport wheels on my disco |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
hi guys i have stormers off a sport (20s) 275 40 19 - they look a little small but seem to drive fine are you saying they are dangerous with these tyres and i quickly need to change to 45s? i checked the weight between ff and sport and its only 100 kg - 25kg per wheel and i never run fully laden |
