|  | Home > Technical (L322) > SRS Warning Light Illuminated |
| rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119      | Steve,
|  5th Mar 2016 11:30pm |
| 6029 king Stephen Member Since: 11 Apr 2015 Location: Sittingbourne, Kent Posts: 101      | Thanks for your reply.  I have read the thread but sadly moving both seats forward and back with the ignition switched on but the engine not started followed by a restart has not cured the problem.  I tried the same procedure with engine started and then a restart and still it has failed to switch off the light.
|  9th Mar 2016 5:16am |
| Weejock Member Since: 30 Dec 2011 Location: UK Posts: 419    | The IID2 can read and reset SRS codes, SRS fault codes most often will stay on until reset by a diagnostic tool.
|  9th Mar 2016 8:32am |
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086      | I had the issue twice on my 04 4.4 and once on a friends and every time it has shown the fault as battery disconnect unit which is the pyrotechnic charge that disconnects the positive lead on the battery in the event of a serious enough crash to trigger the SRS.
|  10th Mar 2016 11:53pm |
| Posting Rules
