![]() | Home > Technical (L322) > LHD/RHD headlights = same? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883
both are different ...
| RRAustria Member Since: 07 Apr 2015 Location: Graz Posts: 32
Thanks!
might be some on ebay..
Yes,
| V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424
I use a RHD Smart in Greece with just the same levers changing the beam pattern. It's passed 2 KTEO ( MOT ) tests since importation. It's not a very difficult test to pass though. 10minutes max of which 5 are emissions and photographs. 2017 5.0 Autobiography Supercharged
| lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513
Off to france in a couple of weeks where is this said lever? Will be easier than silly stickers. |
| Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291
Mine has just passed the French reg. controle and was accepted with the lenses as they are. Just changed the levers.
Robert, from a previous thread wasnt there a fellow french person that had problems with UK light units when he took his for the 'le mot'.. ... - .- -.
I don't know Stan. I went through this severe test last week, not the French MOT, but the DREAL one, which is a level higher, because I have a LPG instal. in the car that was not mentioned on the V5, so they were very thorough and precise, but never said anything about my headlights.
you are indeed |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3277
Mine had the CT 18 months ago with no problems using the switch as shown by Robert. |
| Duracell777 Member Since: 07 Sep 2015 Location: Warwickshire Posts: 128
In the UK only the flat part of the beam is subject to MOT testing, so you can alter the switch for continental driving and leave it, if you don't mind losing the part of the beam that lights up the hedges on the left. Not so bad with a switch to adjust, but if they require stick on beam blockers, then it's easier to just leave them on. Had a Lexus for 5yrs, regular trips to EU. Not a problem.
| All times are GMT |
