Home > Technical (L322) > LHD/RHD headlights = same?
RRAustria
Austria 2004 Range Rover HSE Td6 Bonatti Grey
Are the headlights for 2006 - 2009 the same for LHD and RHD cars? I know that there is a lever on RHD headlights so that they can be used in continental Europe but are the OEM headlights for the UK and e.g. Germany different or not? Does the lever make it a LHD headlight (or vice versa) or just simulates it without having the same lighting pattern?
It would make sense to have headlights that would work in all markets and would be adjusted through this lever...
Post #376831 11th Mar 2016 11:42am
both are different ...
the lenses on the RHD point to the left and the LHD to the right.....the RHD 'tourist' lever just masks the light to the kerb and vice vesra on the LHD...
not sure but i think the L405's have flat beams which dont need adjusting.. ... - .- -.
Post #376832 11th Mar 2016 11:47am
RRAustria
Thanks!
That means hunting down a pair of headlights in continental Europe!
Post #376833 11th Mar 2016 11:50am
might be some on ebay..
your car profile say 2004, is this for a different FF?. ... - .- -.
Post #376834 11th Mar 2016 11:54am
RRAustria
Yes,
I have a 2004 and want to do a facelift conversion. Full conversion packages are easier to find in the UK but I see there is front a end package for sale in Poland (on fullfatrr).
Stefan
Post #376835 11th Mar 2016 11:57am
Thumbs Up ... - .- -.
Post #376837 11th Mar 2016 11:59am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
I use a RHD Smart in Greece with just the same levers changing the beam pattern. It's passed 2 KTEO ( MOT ) tests since importation. It's not a very difficult test to pass though. 10minutes max of which 5 are emissions and photographs. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #376846 11th Mar 2016 1:47pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Re: LHD/RHD headlights = same?
Off to france in a couple of weeks where is this said lever? Will be easier than silly stickers.
Post #376856 11th Mar 2016 2:31pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Mine has just passed the French reg. controle and was accepted with the lenses as they are. Just changed the levers.
Post #376862 11th Mar 2016 2:55pm
Robert, from a previous thread wasnt there a fellow french person that had problems with UK light units when he took his for the 'le mot'.. ... - .- -.
Post #376863 11th Mar 2016 2:58pm
Robert
I don't know Stan. I went through this severe test last week, not the French MOT, but the DREAL one, which is a level higher, because I have a LPG instal. in the car that was not mentioned on the V5, so they were very thorough and precise, but never said anything about my headlights.
Same with my previous Vogue, flew through the French MOT without remarks with the Britlights, so...maybe it helps that I am such a nice guy Whistle
Post #376878 11th Mar 2016 3:28pm
you are indeed Thumbs Up ... - .- -.
Post #376882 11th Mar 2016 3:40pm
Robert
Embarassed
Post #376884 11th Mar 2016 3:46pm
Weegie
Mine had the CT 18 months ago with no problems using the switch as shown by Robert. Thumbs Up John
GAP iiD BT-Sold
Post #376896 11th Mar 2016 5:02pm
Duracell777
In the UK only the flat part of the beam is subject to MOT testing, so you can alter the switch for continental driving and leave it, if you don't mind losing the part of the beam that lights up the hedges on the left. Not so bad with a switch to adjust, but if they require stick on beam blockers, then it's easier to just leave them on. Had a Lexus for 5yrs, regular trips to EU. Not a problem.
Don't know about continental rules though.
Post #376901 11th Mar 2016 5:34pm
