Home > Maintenance & Mods (L322) > side steps without mudflaps?
Deanicuss
2007 Range Rover Vogue SE 4.2 SC V8 Java Black
Can you get side steps without the front mudflaps as I don't want to drill the bodywork, I know you can get deployable ones but i am not prepared to spend that amount.
Post #377342 14th Mar 2016 12:28pm
its best to fill in your car profile so we can see what year/model you have..
as for the steps, i have this type on mine that might appeal to you,
Post #377345 14th Mar 2016 12:41pm
Deanicuss
Thanks Stan, ive now updated my vehicle info Thumbs Up looking at the ones with the mud flaps it looks like you only drill inside the panel behind the front wheel not the actual panel itself.
Where did you get yours if you don't mind me asking?
Post #377350 14th Mar 2016 1:00pm
mine were from ebay..not the best of construction but adequate for my needs.. ... - .- -.
Post #377352 14th Mar 2016 1:02pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Re drilling when fitting front mud flaps…..
The lower wing trim panel needs to be removed and it is that part that needs to be drilled….the panel below the side vents. They aren't expensive new (primed) or second hand in the right colour if you wanted to removed the flaps for whatever reason.
Post #377362 14th Mar 2016 2:35pm
...and metal plates need to be fitted....theres a guide in the accessory fitting on Topix.. ... - .- -.
Post #377363 14th Mar 2016 2:37pm
