|  | Home > Maintenance & Mods (L322) > How clean should oil look after a service? |
| sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613      | I suspect that will always be the case. I'd imagine you'd have to strip down the engine to clean it thoroughly.
|  17th Mar 2016 10:23pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Rule of thumb rar110 drip the engine oil onto your finger, then put your two fingers together as if you are checking the viscosity... If it stains your fingers and does NOT wipe off your finger using a tissue, then the oil is dirty/old... If you need swarfega to clean it off   | ||
|  17th Mar 2016 11:21pm |
| rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119      | Thanks for the replies. I should clarify that I'm quite satisfied the oil was changed. I'm mainly concerned whether both sump plugs were drained.
|  17th Mar 2016 11:29pm |
| wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 808      | That air filter looks far from new, look deep into the folds for dirt and debris to confirm. It should be uniform colour with no blemishes. I have limited experience with Diesels, just done my 3rd oil change on my TD6 and already know the new oil looks dirty after very few miles. Cam-Tech-Craig`s tip is one to remember  | ||
|  18th Mar 2016 1:33am |
| Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227      | Hi Rar110,
|  18th Mar 2016 5:16am |
| rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119      | Ta Jerry.
|  18th Mar 2016 6:24am |
| rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119      | The hole has a plastic cap fitted. It doesn't look very big in the pic but I think it could be 65-75mm diameter. I should have measured it. ______________________________
|  18th Mar 2016 6:29am |
| dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724      | Just my pennies worth , I get my oil changed during a service at every 7'- 10 thousand kms and it does look pretty clean at each change , the mechanic  didn't change cabin  filter last time because it's spotless , he's a BMW specialist and was surprised how clean the oil was himself 2015 4.4 AB
|  18th Mar 2016 7:36am |
| rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119      | I pulled the air filter out and it's clean and new. ______________________________
|  18th Mar 2016 12:24pm |
| Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227      | My new filter against old. The replaced filter is 4300klms old.
|  20th Mar 2016 5:29am |
| rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119      | I think you need a snorkel Jerry. Alternatively, keep a spare filter for trips away. I'll try to remember to take pics of mine after 4-5000km to compare with mine which does mostly city driving. Also, I'm heading out to Lightening Ridge for a trip soon. I take pics after that. It's mostly bitumen but can be dusty. ______________________________
|  20th Mar 2016 10:13pm |
| Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227      | Hi rar110
|  21st Mar 2016 6:30am |
| rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119      | Gday Jerry
|  21st Mar 2016 9:58pm |
| Posting Rules
